Question about Singer 7422
Bobbin case turns in its place
I have a singer 7422, and black bobbin case seems to turn and displace and the whole machine stops working and sometimes cause to break the needle....can't do anything with it.....please helpppppp
tnx
  • heathershep Dec 05, 2008
    I have the same problem. It is a brand new machine so there should be any rough spots on the bobbin case.
  • Anonymous Dec 24, 2008
    bobbin case turns and it bends or breaks the needle
    can't even make one stitch just don't work how can i fix the problem
  • 323 Answers
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
sewman7
Posted on Jul 15, 2008
Why does it keep stopping with lights flashing when filling bobbin?
Singer 7422 keeps stopping with lights flashing when filling ...
www.fixya.com/support/t26006759-singer_7422_keeps_stopping_lights
4 hours ago - Singer 7422 keeps stopping with lights flashing when filling bobbin Machine stops ... Machine stops and red lights flash when loading bobbink.
Dec 13, 2015 | Singer Sewing Machine 7422
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
Installing the hook and bobbin assembly.
The plastic bobbin case should sit on top of the raceway, it should slot in quite easily, once the bobbin case is in put the small metal clip at the top over to hold it in place.
May 27, 2009 | Singer Sewing Machines
Bobbin Case Popping Out
I had the same problem with my singer 20u professional. I tried to find the answer here but no help but I made a call & she said the bobbing might be too big fer the bobbing holder. the bobbing holder is the round metle thing that fits in ure machine. u have to make sure the bobbing ( the thang that holds the thread is the exact same size as the bobbing holder. Hope this helps.
Dec 05, 2008 | Singer 7422
Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
Nov 10, 2008 | Singer 7422
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7422 Logo
312 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
