Question about HP OfficeJet 6210 All-In-One InkJet Printer
Black Horizontal lines
I am getting black horizontal lines when printing anything with my HPOffice Jet 6210 any ideas how to fix this?
  • 35 Answers
Hi!
Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
    1. check if there is plain white paper in the Input tray.
    2. Press Setup .
    3. Press < or >to select Tools and then press OK .
    4. Press < or > to select Clean Print Cartridge and then press OK . The unit prints a test page.
    5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
    1. Open HP Solution Center .
    2. Click Settings .
    3. Click Print Settings .
    4. Click Printer Toolbox .
    5. Click the Estimated Ink Levels tab.
    6. Replace any ink cartridge that is low on ink.
  4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them
    4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
    5. Allow the cartridges to dry before reinserting them.
    6. Close the unit, and plug the power cord back in.
    7. Print a self-test page to check the results. Follow the steps below to print a self-test page.
      1. Press Setup .
      2. Press <or > until Print Report displays and then press OK .
      3. Press < or > until Self-Test Report displays and then press OK . The self-test report prints.
    8. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
- hope it will help to resolve you problem...
Posted on Jul 15, 2008
It's al black horizontal lines/smudges over the printed page. How to cean this?
Black Horizontal Lines are normally caused by a Light Burnt Drum.
The drum in built into the toner cartridge for this machine so replacing the cartridge will fix the problem.
Jan 14, 2015 | HP LaserJet 4L Printer
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
S301 Printing Black Lines
Based on the sample printout, this is a printhead problem. If your printer is still under warranty, please call our technical support team to have the printhead replaced.
Jul 10, 2012 | Lexmark Impact S301 Wireless All-in-one...
Hi - I have a 3-4 year old Canon Pixma IP4500. The initial problem was blurring in places on black text. Nozzle check showed that bottom half of PGBK grid was missing horizontal lines. Took out the print...
one idea is that you rouined printhead with tap water and second idea is to buy new print head or printer.
Note: If you want to replace ink head, be sure to replace purge unit and ink absorber also.
Sep 02, 2011 | Office Equipment & Supplies
Printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
May 20, 2009 | HP LaserJet 5550DN Printer
Black horizontal lines printing on all printing.
Push menu on your printer, then fin maintainance. Then go to clean printer and push the green button. It will clean the cartridges for you and that should help.
Apr 10, 2009 | Dell 924 All-in-One InkJet Printer
Printing anything in black comes out with horizontal blank lines
Have you tried updating the printer driver (first uninstall the existing driver and make sure you have the latest one already saved to your PC before starting). I don't think your current one has mysteriously misbehaved, I suspect that it has been corrupted in some way (a new download may have done something to a critical part of the driver). By deleting and re-installing you are "refreshing" everything. Good luck!
May 31, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
302 people viewed this question
Ben Johnson
