Question about Mitsubishi WS-65857 65" Rear Projection Television
Mitsubishi WS-65857 RPTV Popping/Sparking/Crackling Noise, Then No Picture
Mitsubishi WS-65857 (V17+ Chassis) - Platinum Plus 65 Inch 16x9 Widescreen Rear Projection HDTV (RPTV)
A while back the TV started making a clicking noise now and then. Like an idiot I continued to use it a couple times. One day, there was the clicking and then the TV turned off. After a short while, it would let me turn it back on again but would do it again after a little while.
I pulled the TV out so I could try and figure out where the noise was coming from. I got the general location but I wanted to open it up to see if I could more specifically pin down where the noise was coming from.
Once I took off the rear cover I noticed that there was a lot of dust and even some cobwebs. So I cleaned it up with a little compressed air. Just a fast cleaning job, nothing great. Then I turned the TV on to see if i could better locate the source of the clicking but then the sound was gone and everything seemed to work fine again. I hoped that it was because of dust or something and put the rear cover back on, "intending" to clean it better later.
Of course, once the the cover was back on, it started again. I put a fan behind the TV and it stopped again with everything working fine again. I figured something was overheating since the fan seemed took care of it.
I decided to leave the TV alone until I could get some help diagnosing it better. So it has been left alone for a while now. Last night I went down to look at it again and see if I could better figure it out this time. I turned it on but this time I did not hear the clicking but instead a sort of soft but audible sparking like crackling noise but there was picture and sound.
I turned the TV off right away, opened the back and turned it on again to see if I could locate the specific area of the sound. After consulting the service manual for reference, I am nearly certain that it was coming from the Flyback Transformer (FBT).
I thought I even visually saw a slight sparking coming from where one of the wires connects on top. I turned it off almost right away and I was not focusing my attention right at that area so I cannot be sure since it was very subtle and my mind could have just been playing tricks on me.
For some stupid reason I decided to take the wire off to see if there was anything visible that would suggest it had indeed been sparking. There was a small release tab that was easy enough to release so I took it off and pulled out the wire. The wire fed into a socket within the FBT a couple inches deep or so and had a sort of prong on the tip of it. It seemed to be fine and there were no signs of burn marks or anything like that.
I put the wire back and fastened it back into place and turned the TV on one more time. This time there was a very loud sparking like popping noise. It popped two or three times before I could turn it off and I'm pretty sure there was no picture that time. I didn't want to turn it back on to see for certain, though.
Sorry for being so long winded. I wanted to give as accurate of an account of my experience as possible. Any help or suggestion would be fantastic.
I spent much of last night looking the symptoms up on Google and found from other similar problems from other TVs, that I will probably have to replace the FBT. However, I also read that I may be able to just re-check the solder points, make sure everything is clean and I might not need a new one at all. I would rather take the safer route, though.
I am novice but I am pretty comfortable with a soldering iron and have decent enough experience. However, although I've done it successfully I'm not a huge fan of soldering tiny solder points that are really close to other solder points.
I am not entirely certain since I'm not all that good with the service manual, but I think the replacement part for the FBT is one of the below. I couldn't tell for sure since the part is referenced twice in the service manual but has a different part number each time it is listed. I'm not sure why exactly. It could be because the manual covers multiple models and I couldn't determine which part is for which.
Ref #: Part #: Part Name/Description:
T5A51 334P278010 TRANS-FLYBACK
T5A51 334P265040 TRANS-FLYBACK
Any idea where I can get a good price on one?
If anyone wants to, I can gladly send you a copy of the service manual for better reference. I can send photos of my actual TVs FBT, etc, too.
And finally, do you think I might have caused more damage to other parts by continuing to turn it on after the initial symptoms? Those loud pops did not sound good.
Thank you for any help!!!
  • tdm6 Oct 03, 2008
    Thank you so much for that info!!!
    I can confirm that the crackling noise was definitely coming from the flyback. When it was first started making the noise, I opened up the back and I could clearly hear that the noise was coming from the flyback.
    My initial hunch was to replace the flyback so you have most probably confirmed this. I can look in the service manual a bit better to see if I can determine which part number is the correct one for my model, (WS-65857) but in case I can't... do you know of a parts site or service center that can help me figure out which specific flyback part number I need for certain?
    Also, do you think I blew anything else (hopefully only a fuse at worst) when I was messing around with the flyback wire and got those louder pops?
    Thank you again! It was very good of you to offer your advice. I think it has helped a lot!
    P.S. The site you linked to has some minor layout issues in FireFox but displays fine in IE. I just thought I would let you know in case it is your site. Thanks again!
    President:
  • 4,402 Answers
When they list two flybacks like that it's usually for different models,
more than likely not but who knows.
crackling nose like that is a good indicator of flyback or crt being shorted.
some times you can look on the neck towards the end of the tube and see inside the tube arcing, but then again your picture should be all messed up if that was the case.
fo more info go here http://serviceman.site88.net/index_files/MitsubishiTV.htm
Posted on Oct 03, 2008
Tip
Mitsubishi Convergence IC Part Number List
<b>As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.</b><br /> <br /> <b>Mitsubishi Convergence IC Part # List (complete)</b><br /><br /><br />Ref # / Part # / Part Name & Description <br /><br />CHASSIS: VZ7 <br />MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705 <br />IC8C01 267P141030 HIC-<b> STK392-110 </b><br />IC8C02 267P141030 HIC-<b> STK392-110 </b><br /><br />CHASSIS: VZ8 <br />MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VZ9 <br />MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709 <br />IC8C00 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: VZ6-V15 <br />MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br />MODELS: VS-50800 / VS-50803 / VS-60803 <br />IC8D01 267P120010 IC-H <b>STK392-040 </b><br />IC8D02 267P120010 IC-H <b>STK392-040 </b><br /><br />CHASSIS: V16 <br />MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905 <br />IC8D01 267P120010 HIC - <b>STK392-040 </b><br />IC8D02 267P120010 HIC - <b>STK392-040 </b><br /><br />CHASSIS: V17 <br />MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br />MODELS: WS-55908 / WS-65908 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V18 <br />MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819 <br />IC8C01 267P150010 HIC - <b>STK392-570 </b><br />IC8C02 267P150010 HIC - <b>STK392-570 </b><br /><br />CHASSIS: V19 <br />MODELS: WS?55859 / WS?55909 / WS?65869 / WS-65909 / WS-73909 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: V20B <br />MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: VK20 <br />MODELS: WT-42311 / WT-A42 <br />IC8C01 267P141030 HIC -<b> STK392-110 </b><br />IC8C02 267P141030 HIC -<b> STK392-110 </b><br /><br />CHASSIS: V20 <br />MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411 <br />IC8C01 267P141030 HIC - <b>STK392-110 </b><br />IC8C02 267P141030 HIC - <b>STK392-110 </b><br /><br />CHASSIS: V21 <br />MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55 <br />IC8C01 267P155010 HIC - <b>STK393-110 </b><br /><br />CHASSIS: K20 <br />MODEL: WT-42313 / WT-42315 / WT-42413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V22 <br />MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V23 <br />MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 / <br />WS-65813 / WS-73513 / WS-73713 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V24 <br />MODELS: WS-48315 / WS-55315 / WS-65315 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250 </b><br /><br />CHASSIS: V25 <br />MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615 <br />IC8C01 267P173010 HIC - <b>STK394-250 </b><br />IC8C02 267P173010 HIC - <b>STK394-250</b>
on Jun 10, 2011 | Televison & Video
Tip
CHASSIS: VZ7
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
CHASSIS: V16
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
CHASSIS: V18
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
CHASSIS: VK20
CHASSIS: V20
CHASSIS: V21
CHASSIS: K20
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
CHASSIS: V23
CHASSIS: V24
CHASSIS: V25
on Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits WS-65857 no HD after repair
WELL YOUR LIQUID SPILL MAY HAVE BURNT FOIL PATHS OR EATEN UP SOME OTHER SOLDER JOINTS. A CLOSER INSPECTION ON THE AREA INVOLVED SHOULD SOLVE YOUR PROBLEMS.
Dec 27, 2009 | Mitsubishi WS-65809 65" Rear Projection...
CRACKING NOISE COMING OUT THE SPEAKERS
Your speakers need replacing or you could turn down the volume till it stops and use it like that if it's not too quiet.
Sep 21, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WS 65857 Picture problem.
Mitsubishi's have been known to "burn in" when you have a stationary image on the screen for too long. Usually its not a problem but in some cases I've seen..if its hours and hours of game play..or even places like home shopping network that have phone numbers that never move during the broadcast...it can cause the image to burn the screen.
The projection tubes would not be burned...it would be the mirror viewing screen.
Apr 24, 2009 | Mitsubishi WS-65857 65" Rear Projection...
Tv will not power up, shuts off after 10 second
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Tv screen is scratched
I think This Company can help you to get new screen for your Mitsubishi TV.
Sep 30, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi ws 65857 powers off
Your set is the V17 chassis it doesnt have a DM board, your problem is most likely centerd on the main Circuit board .
Jul 24, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi WS-65857 65" Rear Projection Television Logo
334 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
