Question about Maytag Neptune MDE4000 Electric Dryer
Dryer squelles the dryer is drying but is makes a squelling noise I would like to fix it myself but would like to know whats wrong first but I have a kenmore dryer.
  • Anonymous Sep 10, 2008
    Mine is doing the same thing. The squeak is so loud it's driving us crazy but it'll cost $90 just for a service call. I don't know if there's a real problem or if it just needs some WD40 somewhere? Any ideas?
  • 71 Answers
The sound is thr support rollers or the idler pully, the support rollers located under the drum to the back the pully holds the belt tight. look for meatle shavings or rust dust on rollers.
Posted on Dec 24, 2008
When I turn my dryer on, it squells really bad...the clothes dry fine....it doesn't squell all the time, kinda comes and goes. It sounds like a belt on your car that would squell when it is getting...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 29, 2011 | Dryers
Dryer starts then makes aweful noise then stops timer keeps ticking then when you try to start it again it doesnt do anything
If it is a grinding noise then it is probably a bad bearing. If it is more a squell it could be the belt slipping in addition to a bad bearing. If it is a banging sound it could be the belt.
Jun 19, 2011 | Dryers
Making a squelling noise while turning the drum by hand,and while the drier is operating.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
My Whirlpool Duet dryer is making a loud squeeling noise when drying.
Hello, the squelling noise from your dryer may be coming from the drum rollers. May need to be opened up and lubed. It can also be the idler pulley, also can be lubed. Disconnect power, remove lower panel, and see if you can isolate the noise. Oil where necessary. If you can't get to it, the drum wil need to be removed. If something is locked up or damaged, it will need to be replaced. Caution: Don't stick fingers near moving parts when running :-> Hope this helps, Rich
Jul 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The drum makes a squelling noise. the clothes are drying but the noise is very loud
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 01, 2010 | Amana NDG5805AW Gas Dryer
Dryer starts squelling and cuts off after a few seconds. checked the belt and it seems fine
the squelling you are hearing are the bearings on the motor. The only way to fix the problem is to replace the motor. The part number on the motor is 279827 and price is around $105
Oct 04, 2009 | Whirlpool LER7646E Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Maytag dryer - makes squelling noise when you turn it on
Your glides are getting thin. Not unlike that of shoes on an automobile the glide will wear down and start the old metal to metal screaching.
Get the front off and get the drum out. Remove the glides and replace them. Or flip them over if you are
a cheapskate. LOL Use this GUIDE that tells how to access yer dryer innards and a lot of other cool stuff. Hay I wrote it!
Apr 08, 2009 | Dryers
Maytag Neptune MDE4000 Electric Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
