Question about Zanussi ZWF1640 Front Load Washer
Washing machine not turning machine saying error
Washing machine
    President:
  • 2,712 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jul 14, 2008
Kenmore elite washing machine says IE and wont drain
IE is water-inlet error. Try unplugging your machine and restarting.
If that doesn't work turn off the water, unscrew the water hoses from the machine and check for debris.
Aug 21, 2014 | Washing Machines
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
Dec 05, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Error H1 and H2
this error happen when the temperature increase 7c or more in 1 minutes o by 2c in 2 minutes
Turn OFF the machine for clear and turn ON again.
God bless you
Jul 18, 2012 | Washing Machines
How I fix an error code on a LG wm2669hna washer that says TE error
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
May 17, 2010 | LG WM-2277HW Front Load Washer
There is an error message that says F
If the machine is "frozen" you should be able to fix that by either pressing/holding down the reset/cancel/stop button. Failing that, unplug it for a little while. I believe error code F is related to water filling problems. The machine is indicating that it's having trouble filling with water like it was expecting. This means one of the water lines to the washer may be turned off or connected improperly. If the water supply is ok, that would indicate that the machine is having trouble with its internal sensors. It will need to be serviced.
Feb 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When i try a wash i am getting this "PE" error
that is a water level sensor is bad,. turn off water and unplug unit and call in a service tech.
Apr 26, 2009 | LG WM2487H Front Load Washer
Inlet tube on washing machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 21, 2009 | Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing machine fjs 1025 w can you identify my problem
Put on the machine. Try depressing "end of cycle" button for over 5 seconds. Turn down the temperature knob first. Let me know result.
Dec 27, 2007 | Washing Machines
Zanussi ZWF1640 Front Load Washer Logo
227 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
