Back to:
Tags:
Microwave Ovens
Generic problem for all GE Microwave Ovens
My Microwave oven is a
posted by rwrobbill on Jul 14, 2008
My Microwave oven is a G E Spacemaker Model JVM1331WW 002 the Serial # is SR 966358S The inside of the oven won't light up when the door is open or when it is operating it is dark inside. I thought all I had was change a light bulb. I CAN'T FIND OUT HOW TO GET TO THE LIGHT BULB.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 19, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2962 votes
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
Since it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on My Microwave oven is a:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
I don't have a problem, I would like to know if it is...
Whirlpool 1.6 Cu. Ft. Over-the-Range...
tried to heat up something and it just turned off and...
Microwave Ovens
My child lock feature is engaged on my microwave and I...
Microwave Ovens
I have a Breville microwave oven model no.VMW023 and i...
Emerson MW8102SS 1100 Watts Microwave Oven
Because of the burn spot it always sparks. Can you...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
