Home | Envision | 19" Widescreen Flat-Panel TFT-LCD Monitor | Resolution problems fol...
Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
Problem for Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
Resolution problems following a power lock.
By Heavenshade on Jul 14, 2008
Hello, I apologize right now that I am not quite tech savvy, but then again Im a housewife so what would you expect?
I was getting so irritated with the monitor being stuck on (our toddler is a genius when it comes to renaming hard drives with just a few slaps to the keyboard, and somehow he had locked the power button so you couldnt turn the screen off)
It is an Envision 19" widescreen monitor, and I found how to unlock the button somewhere on google. So all pent up with excitement of finding the answer on my own, I pressed the down button and the power button at the same time and it worked. The screen turned off.
Now this morning I log on and as Im going through the OS loading the screen looked perfectly normal, but as soon as windows was fully loaded. It kicked the display to the right and now I have a good 2" of blackness on my screen.
I turn it off and back on, and when it first comes on it looks normal for a few seconds and then it just slides over. Please help!
Best Solution
posted on May 22, 2009
Very Helpful)
stoneheaded
Rank: Guru
Rating: 91%, 592 votes
Turn on the on screen menu by pushing the number (1) button. Go down the menu to the memory recall function and Push the number (2) button to reset all the controls to factory settings. This should return you monitor to it normal function. If this does not solve your problem, you can call Envision customer support at this telephone number. 1-888-838-6388. They should be able to help you solve the problem. I hope this information helps you with your problem.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Envision 19" Widescreen
Questions and Unsolved Problems for Envision 19" Widescreen
Do you recommend Envision 19" Widescreen Flat-Panel TFT-LCD Monitor?
Answer
Answer
question: monitor says: "cannot display this video mode, optimum resolution recommended... (More)
Answer
I need a 120V = 3A powers supply
Answer
screen keeps flashing to 4:3 in Wide, will not stop
Answer
After just a short while the display on my Samsung SyncMaster 943NW Monitor turns semi-transparant... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Envision 19" Widescreen...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
