Question about E-Machines T2893 PC Desktop
Monitor will not com one when desk top is turned on
I can turn my desk top on and everything will run you can even hear windows start but my monitor stays in power save why would this be?
    Sergeant:
    Champion:
  • 327 Answers
Power management might be the problem sounds like you need to just get in to the power management program and turn it off
Posted on Jul 14, 2008
How do I get my HP computer to boot into windows when I turn it on
mine can boot to 7 things, not just the first hard disk.
usb mem, sd, hdd0,1,CD, and more..
no computer stated by you of th 10,000 models. 1984 to now.
what windows, 14 versions exist.
XP? what?
when you turn the PC the booting is a serial process. (ends at windows login screen)
first it runs BIOS< ROM,
the BIOS ROM, runs POST, (self tests and Plug and PLay)
then BIOS jumps to the first thing in the list (boot order)
and boots to the HDD #0 (default ) F9 key I can change that.' on the fly...
so first is what:?
  1. if a laptop get that bad main battery out first, now
  2. use AC power pack only, NOW. lap or desk top.
  3. does the PCs fan run? (my desk top has 4) if not, power is bad.
  4. does the CD eject? (button) if not power is bad.
  5. does the screen ever show text? like Hit ESC to enter SETUP?> as it did every day since new?
  6. if yes, good, no bad. (bad CCFL lamps>)?
  7. yes, then see if ESC works, F10 , F1 info page work in BIOS.
  8. yes, good, see , now you can boot to 7 things if want.
  9. but if the HDD is bad, you cant boot to that. if its bad.
  10. we run HDD test no as shown on the HP page on topic.
  11. then we try (2006 and newer) the F11 magic recover method.
if the PC is older than 2010, it can in fact have bad CCFL lamps
even PC that are desk tops , the eternal monitor same.
the flash light test. pre 2010 PCs
http://www.pcdied.com/monitors.html#flashlighttest
Sep 29, 2017 | HP Computers & Internet
I turn on my computer. it starts to boot. then blank screen. nothing. it dosnt load into windows nothing. even my mouase dosnt work but it's on
Turn off computer. Now turn it on, and as it is starting hold down the F8 key. you will hear a beep and ket it go. A set of options will come up and choose Safe Mode with Networking. if it manages to get to windows you are fine.
If not, hit fn key + a key with a smzll monitor (usually one of the F keys at the top, like F5 or F6). It might have been put on display mode and woukd onky show if connected to a projector, tv, or external monitor.
Apr 02, 2011 | HP Computers & Internet
Hooked up a monitor and im not getting any picture. i just purchased the computer second hand today. i tried a second working monitor and still no pic. any ideas?..
Assuming that your monitors are good, if nothing is shown on the monitor, that means it does not receive any signal from the computer (or CPU). When you bought it, did they show you the computer and monitor are in good working condition (that means Windows desk top screen comes up on the monitor if it is a PC). If everything was OK when they showed you, but when you took it home, it does not any more, then maybe something became loose while transportation.
Make sure that when you turn the computer on, you hear the fan on the power supply and inside the computer running, and there should be some lights in front of the computer . If you do not hear anything nor see any lights in front of the computer then that is the reason nothing comes up on monitor. If it is the case, you may want to remove the cover of the computer and physically inspect inside the computer to see if anything becomes loose while transportation.
Just some ideas for you to work on. Good luck!
Aug 18, 2009 | Fujitsu Siemens SCENIC E600 Green PC...
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
My desk top started getting slower and slower to turn on. To a point, where the screen would almost flash for 30 minutes, before I get my desk top and can use the computer. Then, one day, it decided it...
You should really run a good scan on the machine to rule out malware infection. Download, install and run the scan/clean in Malware Bytes.
Post your results back here (we can try a few other things afterward but we need to know you have a clean platform first).
Mar 03, 2009 | Dell Dimension 2400 PC Desktop
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Acer Monitor boots up w/computer then "no signal"
you must have disconnected it while the pc was running.damage can occur while doing this as can a keyboard (they are not like USB devices that can be plugged and unplugged while "hot".)
Jul 20, 2008 | Acer AL1916W 19" LCD Monitor
Samsung syncmaster
my samsung 730B moniter will not run how do I fix it?
Dec 28, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
E-Machines T2893 PC Desktop Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
