We have an emachine that when you turn it on it trys to start up but it goes to the safe mode area but it wont start up even if you try to do it in safe mode
    Sergeant:
    Champion:
  • 327 Answers
You rhard drive is eaither bad or it has bad sectors on thing to try is to reboot t he computer with your restore disk and if this does not work you wil need to try a different hard drive
Posted on Jul 14, 2008
My emachine laptop wont work i turn it on and it comes up with a blue screen then truns off now it only turn on to a black screen and a mouse pointer is there any way to just reset it to what it was when i...
try rebooting the computer and as soon as it turns on tap on the "F8" key until a new boot menu appears, choose "safe mode" if the computer starts successfully in safe mode. restart it and allow to boot normally. If this fails comment back as to whether it started in safe mode or not and I will attempt to help you further,
Mar 02, 2013 | eMachines Computers & Internet
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dec 30, 2011 | eMachines T Computers & Internet
When I turn my emachines netbook on, it gives me a error screen saying 'run in safe mode (recommended) and 'start windows normally'. No matter which I choose, it goes to the windows load screen...
there is a recovery tool on emachines usually loaded during you boot the system to safe mode. on my case i restore my machine to its default and reinstall my o/s.. hope it helps
Sep 05, 2011 | eMachines eM250-1915 Netbook
The power snapped off for a few seconds and now my computer will not restart it trys to then goes to the screen that tells you windows couldnt restart and asks how you want to try again i have tried to...
Try this first
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
if that doesn't work, try this:
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
Finally, do this:
http://www.fixya.com/support/r5438565-when_windows_xp_start_final_fix
var fctb_tool=null; function FCTB_Init_a7d37541795e492ebe25472cdafbc42a(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_2a443faf710c4d7d9d373ab98411f540(t) { fctb_tool=t; start(fctb_tool); }
Dec 21, 2010 | E-Machines eMachines Desktop PC
My Emachine T5010 reboots on Windows loading screen.
Before windows loads press F8 on the keyboard to get an advanced menu.
choose the option that says disable automatic restart on error and see what error you get.
Also try the Safe Mode option.
That click sounds like the harddrive is failing.
Nov 02, 2009 | E-Machines T5010 PC Desktop
My cp will not boot up at all. the light turns on but nothing comes up.is there away to fix this? i did try starting in safe mode which is f8 (i hope) it ask to start in safe mode,safe mode with...
You go to Bios mode and choose the frist boost is DVD/CD then save new setting and turn off your comp. Insert Win XP operation disk and see if it could fix the problem.
Aug 12, 2009 | E-Machines eMachines Desktop PC
Dell inspiron wont start!
try to boot in safe mode thru boot menu pressing F2 or F8 or F10 when prompted on startup it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
if it doesnt help then try changing RAM
Feb 22, 2009 | Dell Computers & Internet
Emachine m5310 laptop
This generally is the indication that the hard drive has failed and needs replaced. You can try reloading the system, but 99% of the time when I see this the hard drive is shot.
Jul 17, 2008 | Toshiba Satellite A105-S2716 Notebook
Laptop start up problem
go into bios and turn off virus i assume you have xp
Oct 25, 2007 | Compaq Presario V4000 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
