Question about RCA Scenium HD65W20 65" Rear Projection Television
Issues with the big screen
We have a rear projection big screen TV and the proublem started mild. the TV jittered a little and then would go away but only did that if the tv was on for a while. then it started jittering worse and then all the time.now it jitters and it has double vision. we are not sure how sirius the issue is if we can fix it ourselves or if the tv is junk. we would like to keep it but we do not plane on paying some one to fix it. Any advice
  • Anis402 Jul 14, 2008
    were would the heatsink be located.
  • 4,234 Answers
This is essentially a convergence problem and will continue to get worse. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted on your progress.
Dan
Posted on Jul 14, 2008
Has 2 issues. it takes a while to turn on and every once in a while you will have green lines running up and down the screen. if you wiggle the tv a little the lines go away.
As far as it taking a while to turn on that can be your lamp getting close to the end of its life span.Or it can be the ballast starting to malfunction-As far as those green lines those sound like your light engine
May 12, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
What causes the image on the screen to jitter
Sounds like bad convergence ICs. They are complicated to replace but a good tech should be able to do it for about $100. Let me know how this works out.
hardrocko
Jan 31, 2010 | Mitsubishi VS-70705 70" Rear Projection...
MITSU VS 50705 SCREEN JITTERS WHEN COLD.STARTS AFTER A FEW MIN'S OF WATCHING,LASTS FOR 5 MIN'S,THEN GOES AWAY COMPLETELY ??
set tv on fire,then threw it down the stairs...
now,why would i tell you how i fixed it for 'free' ,when you
charge ''me'' for answers..hmm
Nov 02, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Feb 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Intermittent vertical jitter on mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
JVC TV TROUBLE
If you guys do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
The link provided is for parts for the AV-56WP74 model ONLY. For the 65 inches; you should contact the vendor and provide the correct model number.
Good Luck.
Apr 22, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony 46 in. big screen picture problems
read this
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Jittering screen
Chassis will need to be pulled by a skilled technician.Some specific area hand-soldering is needed and the STK convergence IC's need changing w/OEM or better quality parts.You have a good set worthy of repair.
Sep 26, 2007 | Toshiba 61H70 61" Rear Projection...
RCA Scenium HD65W20 65" Rear Projection Television Logo
221 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
