Cell Phones Logo
A
Anonymous Posted on Jan 16, 2011
Hi i need help reseting my phone to factory condition it keeps bugging out and going black and blank its a sanyo katana eclipse x i need the 6 digit msl restore code
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Jan 16, 2011
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
528178
Points
7608
If your set is nokia do the following step.
Just follow the steps
Make a backup of contacts in your another Sim.
Switch-off your phone.
1. Press and hold there keys at a time;
Green dial key,
* Star key,
No. 3 key
Then Power on/off to switch on the phone.
All switch will be pressed at a time.
.Soon an formatting text, will appear ,then stop pressing those switch, remember. 2. After a few minutes when the Full
phone formatting completed, your phone will back to original system and factory setting.
Hope this helps.
Reset minute counter on sanyo katana
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
tip
Katana Eclipse X Manual Download
Download Sanyo Katana Eclipse X Cell Phone Manual
Have you misplaced your Sanyo Katana Eclipse X Cell Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Sanyo Katana Eclipse X Cell Phone Users Guide?
Follow this link (& click FREE) to download a pdf version of the Sanyo Katana Eclipse X Cell Phone documentation.
I hope that helps.
on May 06, 2010 • Cell Phones
tip
I hope that helps.
__________________________________________
1helpful
I have a katana eclipse x sprint sanyo
It so hard to operate a phone that has no display but you can have maybe your contacts by getting the sim card from your phone and transfer it to the other working phone.
Sanyo katana cell phone alarm clock goes off hour earlier than se
when you set the alarm make sure that you scroll to the bottom and in the preferences you can choose to make it no minutes before for up to 24 hours. this usually happens when you use the calendar alarm instead of the phones alarm
The screen on my phone is all black spots? Nothing works!!!
Usually the LCD screen is connected via flex ribbon wire. Either this needs replacement or the LCD itself.
I can not download music from my PC to my Katana Eclipse X.
Hi, Welcome to FixYa
There are three ways to transfer files to your mobile. USB,Bluetooth,3G Upload
Using a USB connection:
The Sanyo Katana Eclipse is compatible with the "USB Mass Storage" norm.While linking your Sanyo Katana Eclipse to your computer should make it appear as a memory key. Open it and just drag MP3 or other sound or music files straight to your phone, as if it was one of your computer's folder. For the remaining steps, please refer to your Sanyo Katana Eclipse manual. The ringtone section should explain how to select an uploaded file as a ringtone. You can download user guide here
By Bluetooth:
The Sanyo Katana Eclipse is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Sanyo Katana Eclipse.
Via a 3G Uploader:
If none of the above tricks do not work with your Sanyo Katana Eclipse or if you prefer not to buy new accessories, you can still use one of the numerous free "3G Uploader" services available online. 3G uploaders work as follows: Save your own music on their web site and they will provide a temporary URL. Navigating to that URL with your Sanyo Katana Eclipse's browser should download the free ringtone.
Thanks
Phone won't charge or turn on
it seems you have not charged your cell for initial 24 hrs and used the mobile as per the policy of every mobile company. Anyway, switch off your mobile and keep it on charging for next 24 hrs. In case it doesnot works after that also, go for replacement with the vendor.
Blank Screen
I think the your screen may have given up due to long use or due to miosture. This may be fixed by changing the LCD sreen from your mobile's authorized dealer.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
