Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
When i put the micro sd into my phone it tells me that "A media card has been insterted that contains errors. To correct the errors please use a disk error-checking utility on a computer."
  • 101 Answers
Please scan the drive and then try it
Posted on Jul 23, 2008
I am having problem with Nokia 7210 supernova mobile... whenever i am trying to play songs from media player its giving error "not enough memory". plz help
Welcome to FixYa!
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card(Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample) to your phone which will also increase its storage capacity. A Micro SD Card look something like the picture below.
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa.
Have a great day.
Jas247
Feb 17, 2011 | Cell Phones
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Samsung j700 video recording is not save in micro sd card please tell me how its possiable.
Hello
Just switch the storage media from the setting of phone to Memory Card, if memory card is not saving data on it then you need to replace your SD card.
Just for try, format your SD card using card reader from computer and put it again on phone.
Hope this helps
Jan 01, 2011 | Samsung J700 Cellular Phone
I have a 2GB micro sd card for my blackberry when i put it in. It says media card has inserted contains errors. yo correctthe errors use a disk error-checking utility on a computer. what do i need to do?
if this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
Aug 02, 2010 | SanDisk 2GB microSD Memory Card
Cannot format sd card
You are probably trying to format a micro-SD card that is greater than 2GB eg, micro-SDHC (High Capacity) of 4GB or bigger are not supported by 'older' devices. Stick to 1Gb or 2Gb standard microSD cards for your device.
Hope it helps. Let me know how you go.
Jan 13, 2010 | Samsung SCH-u740 Cellular Phone
Micro Sd keeps saying it does not contain supported music files
May be mp3 u are playing on your cell is not supported i.e. bit rate is greater than your mobile supports.
May 30, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
How do I instert a micro SD adaptr into a HP windows Vista laptop
micro sd are too small usually, you need a Micro to SD sleeve, you simply slide the micro into an SD size sleeve and then just put it in your SD slot if no micro slot etc, or buy a usb multi card reader , hey presto
Mar 14, 2009 | PNY 1GB microSD Memory Card
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
37 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
