Question about Zebra LP 2844 Thermal Printer
Zebra LP 2844 label printer
The printer will not print on the left side of the label. I tried using the manual calibration as described on the first page, but the printer would only feed out labels and would not flash as the directions say.
    Habit-Forming:
    New Friend:
  • 26 Answers
If you are facing issues with the Zebra LP 2844 Label Printer and looking for help then you need to dial Zebra Label Printer Support Number +1-888-985-8273. Here the expert technicians are available 24x7 and take these type of queries and resolve them. To connect with the label printer support team you can simply dial toll-free number +1-888-985-8273 or visit our website https://www.printerhelp24x7.com/zebra-printer-support.html and get instant help.
Posted on Dec 05, 2017
We had the same problem and called tech support. they had us adjust th "Q" and "q" commands and this helped
Posted on Aug 01, 2009
I'm having the same problem and got the same result when trying the manual calibration on the 1st page...
Posted on Jul 23, 2008
My ups thermal printer zebra lp 2844 wont print labels properly
press button until flash 7 times to calibrate, turn off, tur on again if pressist, check the setings from the driver, if thei correct. ajust if necessery.
Jul 05, 2010 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 is stalling out on every print.
Maybe the printer is not getting a good calibration on the label. If the status LED is a steady RED when trying to print, then the printer thinks its out of labels. A manual calibrationi could solve that.
1. Turn the printer off
2. press and hold down the FEED key while turning on the printer.
3. keep pressing the key until the status light flashes once, then let go
4. The printer will auto-calibrate for the size of label and then should be ready to use.
Press FEED once after its done and 1 label should feed.
Hope that helps !
Apr 06, 2010 | Zebra LP 2844 Thermal Printer
I can't get my zebra lp 2844 to work. what do i do?
First thing you need to check power is coming to printer or not.
If power is coming check printer is feeding properly or not when you press feed button it should feed one blank label.
If it does not feed label then calibrate printer from driver or press feed button and switch on printer hold feed button for 2-3 seconds and leave it .It will calibrate and print test page.
Aug 29, 2009 | Zebra LP 2844 Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
464 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
