Question about Motorola Mobility ROKR E6 Smartphone
Washing machine door won't open!
My mother has a Miele W770 washing machine. She put a load in, and set it to Wool at 40 degrees. When I heard the cycle end I tried to be helpful by trying to open the machine door by pressing the top left orange button (Tur), but the door wouldn't open so I pressed the while button directly beneath it and it sounded like another cycle was about to begin so I immediately pressed that same white button again and the noise stopped. But the door still won't open. What do I do???? Please help me unblock the machine if that's what I did!!!
I have the same machine and the door won't open using the button. Speaking with technicians gave me a very expensive fix. However, there is an easier solution:
If the bottom panel is removed, just underneath the door there is a protruding section with a "T" slot in it. Inside that is a ring. If that is pulled down it will open the door. I've been using a screwdriver for almost 2 years now.
Good luck,
Andy
(Portsmouth, NH)
Posted on Jan 17, 2009
Why does my machine shrink clothes on 40 degree wash
Some tissues are more sensitive to shrinking than others.
Some clothing cannot be machine washed or only at very low temperatures (hand warm).
Especially woolen fabric will shrink even at 40 degrees.
Be carefull with spinning at high RPM's.
Always consult the label in the clothing:
Jun 03, 2014 | Miele Novotronic Premier 500 Front Load...
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
Feb 22, 2013 | Miele W1926A Front Load Washer
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Miele novotronic w1512 - the wash wash accidently started by my daughter 'cottons @60 degrees'. The machine is fully loaded with darks and they will be ruined if the wash continues. I have tried to stop...
in the user manual there should be a section on advancing the programs on and or in the section of trouble shooting I would take the water outlet pipe and lay it near the ground to drain the water out into a bucket and then as the machine is not plugged in you should be able to open the door in a not on position eric
Dec 29, 2017 | Miele Novotronic Premier 500 Front Load...
My miele w3033 has mold in the rubber gasket. wha...
hi,
you can purchase a cleaning product to run through the machine but white vinegar on a 95c wash also works.don't put any clothes in it though. if it has eaten into the door seal too much you can easily have them replaced. always leave the door open after each wash for about half an hour to let it dry out otherwise a damp environment is perfect for bacteria to develop. lots of hot washes and the door open prevents this.
May 19, 2010 | Miele W2240 Front Load Washer
Washing wool?
I assume you are asking if there is a wool programme.
There should be a seperate wool programme incorporated in the timer or programme control unit, and it is usually a 40 degree wash.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Classixx WVF 2402 Front Load...
Miele W770 washing machine won't cycle through
Hi Sandy,
I had the same problem and some time later it stopped completely. The probmlem is in the Prorammer.
UNfortunately it is very hard to find because the appliance is very old. If you find one, I can tell you in detail what is the sequence to change it.
Sep 14, 2009 | Washing Machines
Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
Aug 20, 2009 | Miele Washing Machines
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Motorola Mobility ROKR E6 Smartphone Logo
90 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
