My remote was different from the one that Trackcar 2365 posted so I came up with this. This will take off the PRO symbol without resetting all of your other settings. If your remote has SELECT and SYSTEM as options instead of ENTER and SETUP, then this should work.
Press SYSTEM Press DOWN arrow once Press RIGHT arrow three times Press SETUP once You should see the Menu screen. At the point you should use the LEFT arrow key to get back to the main system. The system will be in INTERLACED mode from that point.
Was this helpful?
Yes
No
Popular Solutions for Avion AV-DVR100 DVD Recorder
I just bought an Avion AV-DVR100 DVR. It seems pretty good except for one thing: the external a/v...
(More)
I just bought an Avion AV-DVR100 DVR. It seems pretty good except for one thing: the external a/v inputs will not recognize the signal from my Rogers cable box. It records fine from the RF signal, so it's useable. The a/v inputs work ok when I plug in the cable from my digital camera, so it's just the signal from the cable box. Anyone have this problem? All I can think of is the signal from the box is a bit lower than it should be. I can't check it without an oscilloscope, so I guess I'll never know.
can i use my avion dvr 100 without hooking up to the TV..to copy a dvd to a blank dvd? Also what...
(More)
can i use my avion dvr 100 without hooking up to the TV..to copy a dvd to a blank dvd? Also what does CO3 mean? how do we get it to open so we can insert the DVD? Never used. Have no manual. Thank you!!!
When a blank disc is inserted, the recorder flashes a message "disc error", it will play...
(More)
When a blank disc is inserted, the recorder flashes a message "disc error", it will play prerecorded DVDs, CDs, burned CDs fine, the blank DVDs are in great shape. I have an Avion AV-DVR100 DVD recorder
