Question about Gateway MX3560 Notebook
Faint black screen
The laptop was being used 20mins before the problem started. My husband has the settings so that when you close the screen it stays active instead of standing by. So we closed it and then when to open it like 20mins later and it was a faint hard to see screen and then went to an all black screen. Now everytime we power it on it has the faint hard to see screen and has a buzzing sound.
Its a gateway MX3560 and we just replaced the memory at the beginning of the yr because it went bad.
  • DeAmbra Jul 15, 2008
    We've left the computer off for 2 days now and nothing has changed, the screen is still very dim and none of the settings have been changed.
    This computer has been to Iraq and back in the last 2 yrs and has been left on for hours at a time, I'm not sure that the 20 mins it was setting on the dash of the car while driving at night made that big of a difference.
    Sergeant:
    Champion:
  • 327 Answers
Try the power management again if this does not work the try thebrightness of the montior if nothing ele only other thing is that the video card went from being on to long because it over heated you should buy a laptop holder for it to keep it off the table top and this way it gets more air to keep cool
Posted on Jul 14, 2008
Why does my hp laptop screen remain black when I turn it on
It may be a couple of things, inverter, backlighting, the switch that controls the display when you open and close the lid. Here is a video to help you troubleshoot the issue: http://www.youtube.com/watch?v=2Yi6GNFcP3w Have you cleaned the fan, vents, heatsink recently? Take a look at this: http://www.techradar.com/us/news/mobile-computing/laptops/how-to-clean-your-laptop-of-dust-and-dirt-942783
May 08, 2013 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
So laptop will power on, however the screen remains black, or off. The power cord and battery both are in good working condition.
Take a very close look at the screen. If you can see a faint outline of what should be on screen, then it is the backlight that has died; you will need to replace the screen. Try your brightness settings as well.
Feb 28, 2011 | Computers & Internet
My screen turns black, can still faintly see the screen, have to reboot to restore screen to normal. No errors, power supply not too hot, connection to internet good.
are you connecting your laptop to a projector? check you windows settings. Sometimes this happens to some laptop when they're idle. when i encounter that, what i do is to close then open the lid of my laptop
Aug 02, 2009 | Acer Aspire 7720-6844 Notebook
HP Pavilion dv9700 black after closing lid.
when you changed it to do nothing on battery or power did you save these settings........I know it is a silly question but it sounds like the laptop is going into Hibernate mode
Jul 31, 2009 | HP Pavilion dv9700t Notebook PC
The laptop turns on, but the screen stays black
If you can shine a light into the screen and faintly make out the images? Then it's probably the inverter/backlight board, not too expensive or difficult to replace in most cases. Let us know.
Jul 17, 2009 | Gateway MX6912 Notebook
Power comes on but the screen stay`s black dose it have a screen lock or stand by
Black screens can be caused by many things the first bit of video runs through the ram, so try changing the ram or swaping it. the next thing that causes a black screen is the LCD Inverter or the back light bulb to test this is take a flash light and shine it on the screen at an angle and see of you can make any faint images out. Next dis-assemble the laptop and see if the processor is heating up or staying cool.
Hope this helps!
May 02, 2009 | Acer Aspire 1640Z Notebook
My laptop turns on but my screen will not turn on it just stays black
Your backlight may have gone out. To verify this hook up an external monitor. If you get output there (you have to send the output to it by pressing some combination of Function key and another key - Check your laptop manual for how to do this) then most likely you have lost the backlight. Another way of testing it is to look very closely at the screen it may appear black but may have a very faint screen that is hard to see.
That has been my experience. I have heard that there are shops that can fix this.
Mar 16, 2009 | Computers & Internet
Open Questions:
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
