Am thinking of replacing the Power Supply for the reason you mentioned, ppl have mentioned that the caps go bad after 1000 hours, and I'm thinking that's easy to replace too (is there a safe/easy way to discharge them.. a light bulb maybe?) You also mentioned a possible adjustment, do you know what voltage one would measure and adjust to try and eliminate this red snow? Replacing the logic board did nothing, have ordered the X-sustain board, next the Y.. but are these not involved in the red snow effect? OK, fixing this plasma is not as easy as fixing a scratch built PC.. I learned that much...:) 40$ for advice that works... u got a paypal or po box? :)
-   I may have a similar problem. I connected my new blu-ray disc player. After a couple movies, I noticed my Phillips 42PF7320A having the screen covered with a diagonal pattern of red dashed lines. It came and went during the movie, at random. I have my blu-ray player connected to the tv via component video.-   plazphillips
Hola mi nombre es javier y tengo una tv de proyeccion de 52", de la nada ahora no enciende, a...
(More)(More)
Hola mi nombre es javier y tengo una tv de proyeccion de 52", de la nada ahora no enciende, a que se debe este problema?? alguien me podria ayudar por favor?? tendra arreglo??
gracias
buenos dias mira mi pregunta es .. tengo una tv de proyeccion samsung de 52 pulgadas pero traia un...
(More)(More)
BUENOS DIAS MIRA MI PREGUNTA ES .. TENGO UNA TV DE PROYECCION SAMSUNG DE 52 PULGADAS PERO TRAIA UN POQUITO DISTORCIONADA LA IMAGEN DE UN LADO (SE VEIA DOBLE DE LA MITAD DE LA PANTALLA PARA EL LADO IZQUIERDO) Y TUBE LA GRAN IDEA DE MOVER EL REAJUSTE DE LOS COLORES Y LA DEJE PEOR POR QUE AHORA TODA LA PANTALLA SE VE DOBLE O TRIPLE POR LO DE LA CONVERGENCIA Y APARTE DE TODO ESO LE CONECTO EL CABLE O LA ANTENA Y SE ME APAGA SIN ANTENA O SIN CABLE NO SE APAGA... CUALQUIER COMENTARIO TE LO AGRADEZCO... GRACIAS
where do i connect my hi-fi into the tv for the sound to come out the hi-fi speakers there are so...
(More)(More)
where do i connect my hi-fi into the tv for the sound to come out the hi-fi speakers there are so many rca outlets.please help
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are...
(More)(More)
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
