Question about Radio Shack Cinego D-1000 Multimedia Projector
Connecting cinego projector to hp laptop
I've connected my cinego projector to my hp laptop. I dont know what to do on the lap top to make it read.
  • 1 more comment
  • Anonymous Jul 16, 2008
    I would like to know how to connect my HP laptop screen to a Sony Projector.
    Best Regards,
    Prasad Pullabhatla
  • childprodigy Jul 26, 2008
    I am trying to connect my laptop to my cingo projector but it is not detecting the device
  • gazza54321 May 11, 2010
    thanks alot worked a treat this had me baffled for a long time
    thankyou!
    Problem Solver:
  • 17 Answers
Don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Posted on Jul 17, 2008
Why wont my movietime projector play from my lap top when connected by the D-SUB, i have used fn +4
All lap tops are different and some are f7 or f10. The picture that your looking for is the one square half way over another square. and make sure that the input selected in the projector is the same as the input you've connected the laptop to.
Feb 28, 2011 | Optoma MovieTime DV10 Multimedia Projector
TRYING TO GET THIS PROJECTOR TO SYNC WITH DELL LAP TOP
press Fn button and F5.
or in display properties use the secondary display to be set as primary.
dont forget to vote fixya rating
Sep 13, 2009 | BenQ PB6110 Multimedia Projector
Connect Cinego to MacBookPro
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
Apr 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Projector can't connect to laptop
We just solved a similar issue. Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
For the PICO in particular, it looks like those are in general for small mobile devices (320 x 240 or less displays), and the PK102 model has native VGA (640 x 480) support with extended support for 800 x 600. You will not be able to use this on most modern computers except at the lowest resolution setting for the PC.
Feb 19, 2009 | Office Equipment & Supplies
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
Toshiba LCD projector
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible.
Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop.
some laptops also require ddc communication between external connected devices.
Try to use a full wired ( except pin 9) VGA cable.
succes
Aug 31, 2008 | Radio Shack Cinego D-1000 Multimedia...
I have a hp deskjet f2180 all in one printer scanner copier we have tried to add to my lap top but the lap top does not recognise the hp deskjet f2180 and we dont know what else is compatable with
What operating system are you running on your laptop? This model only supports Windows 2000/XP/Vista and Mac OS/X. Make sure you have installed the printer USB drivers (included on the printer software CD) first. If you are connecting the printer directly to the laptop, all you should then need to do is connect the printer to the mains power, turn it on, and connect the USB cable between the printer and the laptop. If you are connecting to a printer that is connected to another computer, you mus make sure printer sharing is enabled on the computer the printer is physically connected to.
I may be able to provide a better solution if you can provide more information on your Laptop operating system and how the printer will be connected.
Jun 15, 2008 | HP Office Equipment & Supplies
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
439 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
Frank Zabroski
Frank Zabroski
xxxxxx xxx
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
