Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
Usb hdd is not recognized i have 2 usb ports in the back if i switch mouse to 2nd port will not work if I set the hdd on 1 port it says it has a usb device but does not recognize it
  • 594 Answers
If you are runninf windows xp than do an update to service pack 2. that should fix the usb problem..... you can do that by going to www.microsoft.com and clicking on the service pack 3 option than you will need to install the update software whitch only take about a min. than press express and the software will scan your computer for the latest updates. you might need to do this 2 times if ou are running with service pack 1.
Posted on Aug 12, 2008
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
I have a Trendnet TK-209 KVM switch. My keyboard and mouse (MS wireless) that worked well for a year stopped working through the switch. they work well if connected directly to each computer.
I can confirm the same problem happened with me just now. I have TrendNet USB/KVM TK-207 and was flawlessly working with Logitech K260 Wireless Mouse and Keyboard Combo, but today on both computers all I can see is the error:
USB Device not recognized - The last USB device you connected to this computer malfunctioned and Windows does not recognize it.
I unplugged the usb wireless adapter and connected it directly to the PC - it worked like a charm again. I have tried to connect the wireless adapter to the mouse port hoping that the keyboard USB port is causing problems, but all I got was the same error. I have tried to conect a normal USB keyboard, but again the same error I get for both - the mouse and keyboard, so it is more than obvious now that the USB ports of my KVN Switch are malfunctioning. I will try to leave it for a while if it got hot somehow as it was connected for more than 6 months working perfectly fine, but if not, I am heading to the store for support/replacement.
May 02, 2011 | Trendware TK-207K 2-port USB KVM Switch
My DEll mouse stops working when it feel like it. have to shut computer off and turn back on for mouse to light and work for awhile again. What"s wrong?wrong
Try your mouse in different USB ports, if it works well in the other ports then you know your original port is bad. If the mouse still acts up, then go ahead and try another usb mouse in the computer. If the 2nd mouse is working then you know the original mouse is bad. If the 2nd mouse is not working then you know that the usb ports on your motherboard are bad.
May 17, 2010 | Dell U0636 Mouse
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
When working on my computer Optiplex 745 Windows XP professional the optical mouse becomes non operative (no response, no red light). If I shut down and restart the computer it is fine.
Make sure the HDD jumper is set to master and see whether it helps.
If not the HDD is not recognised by the PC. Also make sure the connections between the HDD and mother board.
· Try a different IDE cable
· Try a different HDD an
All the best!
Jul 06, 2009 | Dell U0636 Mouse
My Trackman Marble FX stopped working after dealing with a virus. Never could get it to work, maybe I just wore it out. Bought a Logitech optical mouse but the left click is messed up. It locks and does a...
It could be a bad Trackman or a bad PS/2 Port.
1st test if it's the port by trying another mouse, or by trying this Trackman in another known working PS/2 port on another computer.  (don't forget to reboot each time you plug in a PS/2 device)
2nd, you can try using a PS/2 to USB adaptor.
These two have great reviews...
$12 TRIPP LITE USB to PS/2 Adapter Model B015-000
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812120006
$20 SIIG JU-ACB012-S2 USB to PS/2 adapter cable
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16812191021
Best of luck getting that wonderful Trackball working again!
~Andrew
EmpoweringSolutions
Feb 20, 2009 | Logitech Trackman Marble FX Trackball
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Mouse not recognized/ mouse port not working
I kept hold about 30 seconds the blue light button on the USB controller device and it worked!. I guess that's the way to sinchronize both the mouse and the USB controller of the mouse. Ramón.
Sep 07, 2007 | Computers & Internet
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
