Question about GE Microwave Ovens
My Microwave oven is a G E Spacemaker Model JVM1331WW 002 the Serial # is SR 966358S The inside of the oven won't light up when the door is open or when it is operating it is dark inside. I thought all I had was change a light bulb. I CAN'T FIND OUT HOW TO GET TO THE LIGHT BULB.
    Genius:
  • 3,422 Answers
HI,
Instead of using an offset screwdriver a regular one will work fine. Open the top cabinet door for a better angle, bend the plastic a little and you should have a clear shot at it. The bulb is nothing special its a g8 base 120v 20w bulb.
Posted on Jul 14, 2008
  • Priya darshan Jul 14, 2008
    There is a grille above the door and clock/cooking controls that
    extends the width of the unit. You need to remove this to get to the
    light receptacle. With the power to the unit off (unplug if you have
    access to it), get on a chair with a Phillips head screwdriver. Look
    down from the top and you will see two screws about 6" in from the
    ends. If you don't see the screws, open the cabinet doors above the
    unit (mine were blocking the screw heads). Remove the screws and set
    aside. Pull girlle towards you at the top being careful not to break
    the tabs at the position where the screws you just removed are located.
    After the tabs are out the grille should lift up (there are three
    hook-tabs along the bottom). Set it aside. Over toward the right you
    will see a smaller vertical grille. Just to the left of this there is a
    void with a Phillips head screw facing you. Remove the screw from the
    receptacle tab. Lift up the receptacle tab on the right. When the
    receptacle is clear on the right, move the receptacle to the right to
    release it from the tabs on the left. Lift the receptacle up until it
    clears the housing it just came from. Pull it gently toward you, rotate
    it bottom-toward you, and you will see the bulb to be replaced.
    Please don't forget to rate or accept the solution.
    Master:
  • 497 Answers
Did u by any chance try cleaning the interiors..recently?
    Master:
  • 555 Answers
Does this model have an incandescent bulb, or a fluorescent ballast?
  • Matt Jurach
    Matt Jurach Jul 14, 2008
    I found the specs for your microwave.
    See page 39 of this manual for instructions on replacing the bulb. You'll need to remove four screws and the top grille to get at the light bulb.
    You will need a 30 W replacement bulb (Part # WB02X4235 from GE, or get a generic at your local hardware store).
JVM1331WW 002 What is the cu. ft.?
The "13" in the model number means it's a 1.3 CF model.
GE Customer Service (here) can tell you if they have a "drop-in replacement" model.
Apr 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
What is the serial # range for GE Spacemaker microwaves vintage 1984-1985
That would be difficult to track down, but you can use a universal door switch "open or closed " selection making it handy, some tv repair shops still may carry some parts, appliance repairman another choice.
Mar 06, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker model JVM140H 002. The night lights work, but the main lights do not work, I can hear the relay clicking and the night lights go out.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave doesn't have power
Sounds very much like the magnetron is at the end of its life , if everything else on the oven is working but you don't get that familiar hum as the magnetron kicks in and I am afraid they can cost as much as a new oven especially with the repair cost , time to go to the store and get a new one it will probably be cheaper ... Regards Vortash
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Microwave oven is a G E Spacemaker Model JVM1331WW 002 the Serial # is SR 966358S The inside of the oven won't light up when the door is open or when it is operating it is dark inside. I thought all I...
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
Since it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | GE Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
329 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
