1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
The purpose of weightlifting gloves is to protect the hand from developing corn and warts and is also intended to protect the fingers and the knuckles.
