Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Odor the door was left open a crack over night, some fish thawed out and the water went into the drain. How do you empty and clean drain ...and get rid of odor?
  • 481 Answers
I would take the machine outside and blast it with a hose. use hot water mixed with bleach and dish detergent to clean the inside  thoroughly.
Posted on Jul 14, 2008
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Mar 26, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
I left the door open a crack for over 12 hours. A few things thawed partially. After closed the door, it sounds like it is running but nothing is freezing.
Turn it off for 1hour and restart, the reed valve got hot and wont open, do it and get back to me urgent or you will lose the lot. Russ
Aug 22, 2011 | Frigidaire Freezers
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain...
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Feb 06, 2010 | Freezers
Sears Freezer, Model 253 9284013-unable to locate manual, nor online. Freezer did not maintain freezing level, fish thawed slightly, dripping liquid onto bottom interior. It froze over. On bottom, at the...
Your problem could be caused by a clogged drainage tube. even though you may have removed the ice it may still have a clog. my suggestion would be to take all of the contents out of your fridge and let it sit unplugged for atleast 24-48 hours with the doors open this will eliminate any left over ice that may be clogging your drain tube. if this dosent help then you may have a defrost heater problem, or possibly a defrost termination switch problem. as for the smell i know that vinegar works well for getting rid of odor. ther eis also a product you can purchase called fridge aid, it is a charcoal based air purifier and should work well.
Oct 11, 2009 | Kenmore Freezers
The door was left open and things thawed out, is there a tray or drain I need to clean. It smells even after I have cleaned it.
there is a condensate pan under the freezer, but when the compressor is on, the heat from the high-side line evaporates it. but still check to see if there is too much.
Jul 29, 2009 | Frigidaire Freezers
Trying to see if it has a drain plug
FILL 1 or 2 shelves with crumpled up newspaper . The ink in the newspaper , will absorb odor . May take a while , but it's the only proven way I know of , to remove fish odor . May have to change paper every couple of days , till the odor is gone .
Jun 16, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Layer of water on bottom of freezer,causing problem opening bottom drawer, having to use hair dryer to thaw.
If it is a frostless your drain tube is plugged. The water cannot go through the whole to the drip pan so it flows over into the freezer. Unplug the freezer and leave the door open all day to thaw. Or take the back wall out of the freezer and unthaw the drain tube with hot water and a hair dryer.
Nov 17, 2008 | Freezers
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Jan 18, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
135 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
