Ink catridge problem shown on screen. It says"the following ink cartridge appear to be missing or damaged.Refer to printer documentation" My printer is a HP photosmart 3310
After finding an old ink cartridge and inserting it back in the printer,I found that the printer worked o.k so I found the new cartridge to be faulty and have now replaced it.
Posted on Jul 15, 2008
How do I stop the message of 'Missing or damaged cartridge
Delete and reinstall a printer driver and then go into the protery of the new driver and search for update go to inksell.com they will give you the latest driver
Jun 03, 2017 | HP Officejet Pro L7680 All-In-One Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
My HP Officejet Pro L7650 printer says "Cannot
Hi
Firstly you should check if there is any covering on the ink nozzles
Did you try to allign the print catridges after you changed the same.
Take out the catridges and clean it with a piece of cloth again put it back and check
if still it doesn't work
If you have done it perform a semi full reset:-
Unplug the power cable at the back of the printer
Press and hold down the (#) and the (6) key together pplug in back the power cable
Leave the keys it should say on the screen semi-nvm reset if it doesn't says so its not done properly .. try to do it once again after that it should align the catridges automatically
This should solve your problem if not try with a different catridge
Aug 24, 2011 | HP Officejet Pro L7650 Printer
Getting "Catridge error: Refer to
if the cartridge is not sensing poperly this error may occur.clean the cartride contact and try it.
the following link may useful to you.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01571812&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3441011
Aug 08, 2011 | HP J3680 Officejet All In One Printer
Catridge error refer to device documentation to troubleshoot
You can go to HP's site and find that you have a problem with one or more of your ink cartridges see:
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
It states: " Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing.
If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might
need to be cleaned.
If there are no ink cartridges missing from the HP All-in-One, and you still receive this message
after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Contact HP
customer support." Go to:
www.hp.com/support
Basics Guide 29
Troubleshooting and support
Apr 01, 2011 | HP Photosmart C5180 All-In-One InkJet...
Screen says "the following ink
I am having the SAME problem!! The cyan color for some reason!!! All of these are BRAND new HP ink cartridges!! Have you figured out how to fix this??
Feb 21, 2011 | HP Photosmart D7560 InkJet Printer
NX415 inkjet catridge refill
This is what I found on the Web. You can download the Manual if you like. Click on link below. Not able to put all here, do to limitation.
http://files.support.epson.com/htmldocs/nx415_/nx415_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Remove and Install Cartridges
Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones.Caution: not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1.
Turn on your Epson printer.
2.
If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press or OK (NX410 Series).
If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
Your printer model may vary from the ones shown in this section, but the procedures are the same.
Do not open the ink cartridge cover while the print head is moving.
Apr 04, 2010 | Epson Stylus NX400 InkJet Printer
Receiving the message "Ink Catridge problem: ink cartridge appears to be missing or damaged". I've tried everything from cleaning cartridge holders to replacin cartridges. Nothing works and the printer...
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Nov 24, 2009 | HP Photosmart D7260 Printer
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
