DISH Network DTVPal DVR by Logo
Posted on Jan 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get new DTVPal DVR for 2 month. and it can not start. press start on remote. the green light just on less a second and off by it self. who can I get wanrantty, where can I have custom service phone number?
Mike.H-DISH_Network
Level 2:
  • DISH Network Expert 246 Answers
  • Posted on Jan 16, 2011
Mike.H-DISH_Network
DISH Network Expert
Level 2:
Answers
246
Questions
0
Helped
90900
Points
341
Hi this is Mike Houston of DISH Network. I will be more than happy to help you with that phone number 1-800-333-3474. We also have troubleshooting as well on DISH Network and that link is
http://www.dishnetwork.com/supportsection/troubleshoot
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 • Televison & Video
Hello
Hello! Are you having a problem with your DTVPal Dvr???
1helpful
What is the phone number for Dtv???
I would be happy to provide you with an Email for any concerns that you have with your DVTPal. Feel free to contact us via [email protected]. If you would like additional information on your DTVPal in general please visit: http://www.dishnetwork.com/dtvpal/support.shtml.
Phillip Chang
DISH Network Customer Service Representative
Remote codes for directv HD DVR and westinghouse tv
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10463, 10623 Westinghouse 00002 dvr hd
1helpful
I bought the car with wiper alarm system and remote start. it wont start the vehicle, could it be because of low battery, the alarm its self works fine, arm and disarm
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
My dvr remote 2 has been taken over by my other tv2 remote is there a way activate the former remote? I just had a hdtv dual dvr installed and a new dual reciever. I already had a dual dvr. When I had the...
Unplug one of the receivers. Now go to the second and with the TV1 remote press MENU-MENU and you will see the two remote addresses displayed. On the TV 2 remote that is associated to turn off the TV2 with this receiver press and hold the SAT button on the top left of the remote until all the buttons across the top illuminate. Now key in a two digit number that differs from the one for TV2 displayed on the screen. Now press the pound sign and the SAT button will flash three times. Next press the small record button until the TV2 address changes to the correct two digit number. Now you should be able to turn the other receiver back on and be able to control each TV2 independent of each other. Thanks for using Fix Ya. If you need further assistance let me know.
6helpful
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
DVR remote not working on tv 2
The receiver is more than likely in single mode. Go to the receiver and ensure the green and blue lights are both on. If not press the door on the right of the receiver and press the mode button until the amber light illuminates closest to the green light. If it will not do this you can press the front panel power button and see if that will allow you to be able to do so , if not try unplugging the unit from the electrical receptacle for thirty seconds and try again. if these fail you will need a service call to have the receiver replaced.
As for the other receiver recording on all four tv's I can not answer that as I do not know the cabling system at your home and whether there are switches etc. It is really an issue that needs to be addressed with more specifics as to all hardware in the system or dealt with by a technician.
I will be more than happy to troublleshoot this for you if you can tell me the other receiver type and if there are any switches in the system and what type of dish you have e.g. 1000.2, Super Dish, or a two dish solution.
Hope to hear from you soon.
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
