Question about Akai PDP4290 42 in. EDTV-Ready Plasma Television
Akai pdp4273m1 has sound but no picture
I have a Akai pdp4273m1 and it works like nothing is wrong with it but it has no picture. im able to turn on the tv with remote and manually, adjust volume and change channel. How can i fix this?
  • 1 more comment
  • cueevang Jan 24, 2009
    I also have sound but no picture -- please help.
  • blupro May 02, 2009
    i have the same problem how can i fix this i have sound but no picture.
  • Anonymous Mar 20, 2014
    the sounds fades in and out, when tv has no sound there is a picture of headset on volume bar, when i adjust the volume headset picture is gone and the volume works, need to know if sound is going or does this have something to do with the pic of headset on the volume bar
    Problem Solver:
  • 3 Answers
I have the power board for sale for 150.00 at 864-325-1304 or ace.gutters@hotmail.com My plasma glass broken so selling out parts.
Posted on Oct 08, 2009
I also have the akai PDP4273M1 tv with power and no picture and I looked at the power supply board inside and found 1 of the FMG26S chips blown and I am looking into replacing this to see if that does it and if not do a search for SANKEN PSC10165B M and for approx 170.00 you can get a whole new power supply for it and its easy to put in..
Posted on Oct 28, 2008
I have A three year old AKAI 42 inch plasma tv---PDP4273M1---Mostly used as PC monitor. It was working just fine when I turned it off. When turned back on the next day, the on indicator light came on and...
Check to see what input setting the tv is on. It could still be looking for a signal from the pc input connection and no pc is hooked up thus getting no signal. Have the device you are trying to display on the tv connected and turned on and cycle through the inputs on the tv until you get a signal.
Sep 07, 2010 | Akai PDP-4216M 42 in. Plasma Television
No picture or sound have power and nothing wrong with cable box
Have you fixed this yet?Please let me know.Thank You very much!
Tyler
Jun 01, 2010 | Akai LCT2662 Television
LCD TV Akai 27" NO PICTURE, NO SOUND, JUST A POWER LIGHT
Could be an open internal fuse or power supply failure
Mar 26, 2017 | Akai LCT2721AD 27 in. LCD Television
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Picture on Akai PDP4273M1 suddenly degraded drastically - no whites, very low contrast. Turned it off for 10 minutes then back on, instead of bright blue I get most black splotches with some blue. Any...
You could smash the TV and find that it will work better or call a local repairman. I know the exact problem with this TV, but only a technician should even open a TV. The guy I got the TV from totally butchered the inside of his Akai in a failed attempt to fix his TV himself. Instead, he created a fire hazard and is lucky he did not burn his house down.
Apr 30, 2009 | Akai PDP-4247 Television
Akai TV repeatedly turns off and on
Yeah. I had the same problem. About 1 month ago my AKAI PDP4273M1 TV began turning off...then on. I happened to stumble on a temporary solution. I held one of the buttons down on the t.v. without letting go...and what do you know....the tv stayed on. So I rigged it to where the button (the "source" button) stayed in and I stuck a small object into the hole next to it (a small nail in my case). The catch is you have to use the remote becase none of the buttons on the tv work. Wonderful...so...I got that fixed and then today my picture gave out about 75 percent. What a Piece of S%#* TV. That is all I can say. My 2 1/2 year old TV is a POS and is going into the dump. Can you say hello to a new VIZIO. Hope that helps. Remember. NEVER BUY AKAI TV PRODUCTS AGAIN!!!!!
Jan 19, 2009 | Akai PDP4273M Television
Akai 32" lcd
The sound is a failing relay. It seems you have an issue with the power board. You may have to swap out the board to get this rectified. I recommend contacting a local service center to get this repaired.
Jul 02, 2008 | Televison & Video
Screen went out
This sounds to me that you blew a fuse, or something wrong with the mainboard. im no expert, by any means...Have you taken up the courage to open it up? there is about 40 screws, just draw diagrams and such where it goes.. also, there are 2 small screws by where the computer and dhmi digit port are (like your comp at home) AND also the nut on the coax. after this, it's home freee. power is right on top middle. check out my other post for pics of it...Hope this helps!
May 12, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai PDP4290 42 in. EDTV-Ready Plasma Television Logo
1,337 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
