Question about Compaq Presario M2000 Notebook
Access motherboard I need to replace the a/c power cord jack as the old does not work. How do take the damn thing apart to get at the motherboard on my Presario M2000
  • lwyergirl Jul 14, 2008
    Have the same issue
    Sergeant:
    Champion:
  • 327 Answers
Welcome to FIxya
As for you taking apart your laptop to try to fix it if you asking me how it is not a easy job but here is a website that can explain more in stead of me typing this
https://www.fixmyjack.com/How_to_replace_a_dc_jack.html
hope this helps you out have a good day :)
Posted on Jul 15, 2008
Is not charging battery
If the laptop works with the AC Adapter Power Cord ok without any problems except the battery is not charging, then the battery is dead. Batteries only have a useful life, then they have to be replaced.
If the laptop does not work with the AC Adapter Power Cord then either the Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of these is bad, a good battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | HEWLETT-PACKARD Hewlett Packard 413671-001...
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
Laptop battery light won't stay on
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite Computers & Internet
My battery light is off.
Jun 03, 2012 | Toshiba Satellite A105 Notebook
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
May 22, 2012 | Dell Inspiron 1525 Notebook
My new laptop battery is not charging
Maybe the battery is bad. Just because it's new does not mean it will work.
Does your laptop power on and work with the AC Adapter and Power Cord? If not, that is why your battery is not charging. You need a New AC Adapter & Power Cord or the DC Jack where the Power Cord plugs into the laptop is bad or broken.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 15, 2012 | HP Compaq nx7300 Notebook
Presario laptop issue with power indicator light and detecting powers supply
Sounds like your DC Power Jack is bad or broken. The DC Power Jack is where the power cord plugs into the laptop? Most times it get damaged by too much stress on it such as sitting in bed with the laptop, or putting the laptop in the laptop bag with the power cord still plugged in.
Take an ink pen and put it into where the Power Cord normally plugs into the laptop. If the pin inside the DC Jack is loose or wiggles then the jack is probably bad. Sometimes the jack can be completely burned out and you can smell smoke .
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 05, 2012 | Computers & Internet
My Eee 4g surf netbook won't charge at all. Upon turning it on, it runs for a second, then shuts off due to a lack of battery power. The charge cable's light is also not turning, so that may
I think your DC Power Jack is bad. The DC Power Jack is where the power cord plugs into the laptop. If it is bad, then a good power cord cannot charge the battery, nor can the laptop turn on once the battery is drained.
You say it smelled burnt, that might mean it took a power surge. I always tell people that before your plug the power cord into the electrical outlet on the wall to remove the other end of the cord from the laptop. That way if you get a power surge you will only damage the power cord and not the dc power jack or motherboard.
Anyway, take an ink pen and push it into the dc power jack and see if there is some movement. The little pin or the casing of the jack should not wiggle.
The DC Jack is soldered onto the motherboard. To replace it you will have to take the laptop apart, desolder the old dc jack and solder a new jack onto the board. Sometimes the DC Jack sits in a slot rather than being soldered. The palmrest and bottom case helps to keep it in place. This type of DC Jack usually has a cable harness that plugs into the motherboard.
Apr 02, 2012 | ASUS Eee 4G Notebook
Exact same thing
Usually this means replacing the motherboard, but you could also have a bad power supply/charger. How old is the computer and is it still under warranty?
Aug 09, 2009 | Dell (8N816) Motherboard
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Compaq Presario M2000 Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
