Question about LG KU990 Viewty
Cant until install my palm desktop program so that I can re-install it to fix a syncing problem that must be corrected
  • dnhowell Jul 15, 2008
    How can I rate him a 100 % ?!?!?
I was assisted by AvioriX. He was extremely patient since I am computer illiterate. He helped me solve my problem. Thanks so much!!! Donna Howell
Posted on Jul 15, 2008
I cannot sync my Palm Tungsten E with MS Outlook.
  1. Step 1 Install the Palm Tungsten software. This software is required in order to sync Palm Tungsten with Outlook Express. To install the software, place the CD-ROM in your PC and follow the on screen instructions.
  2. Step 2 Use the HotSync cable included with your Palm to plug into the USB port of your PC. You will then plug the other end of the cable into your Palm Tungsten.
  3. Step 3 Open the HotSync Manager program on your PC through the "Start" menu or clicking on the icon. You can manage the different programs available for synchronization through this program. Select Microsoft Outlook as one of the applications that you want synched onto your Palm Tungsten.
  4. Step 4 Turn on the Palm Tungsten. You will see a star icon on the menu of your PDA. Tap this star with your stylus to start syncing Microsoft Outlook Express. A dialog box will appear on your PC during the process to know the progress of the synchronization.
  5. Step 5 Unplug the cable from your PC and Palm Tungsten once the sync is completed. As the Palm resets, you will now notice that Microsoft Outlook Express is available on the PDA.
Jun 25, 2009 | Computers & Internet
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
Sync. gets frozen when reaching the "media" part.
CHECK YOUR TREO SYNC SETTINGS.RICHARDM69(WRITE PROTECTED?)
Dec 23, 2008 | Palm Treo 755p Smartphone
Can't install palmone quick install on vista
Vista and quick install work just fine for me.. Here is the process.. Using latest 4.1 from palm.com
you may loose palm desktop data and the users you have created
shut down hotsync, quick install, and palm desktop
go to start.. Programs... Palm desktop
highlight hotsync manager and left click... Go to properties...
Go to compatibility tab and tick run in windows XP mode
select disable visual themes and at bottom select run as administrator
OK that and go to quick install and palm desktop and do the exact same
restart hotsync manager (you will need to allow the program now)
start palm desktop (you will likely need a new user created) (you will also have to allow)
start quick install and poof it will work like new on your vista PC
I struggled with that one for at least 45 min myself but I can now go to quick install and find my application and upload to my palm and sync with ease!
Hope that helps
Aug 17, 2008 | Computers & Internet
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
Palm III sync program for outlook 2003
You can get a compatible palm desktop software and install it. it will let you sync again. you can get the palm desktop software from link below http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Sep 13, 2005 | Palm III
How get Drivers PALMUSB.SYS for USB cradle
Problem is fixed: Not sure how I fixed but I think it was when I shutdown PC and restarted. Then I tried to SYNC again AND then I found WINDOWS saying it found new hardware (the cradle). This time I knew to say I'd tell where the drivers were and I chose the Drivers directory of Handspring directory and the installation proceeded OK this time. (drivers are PALMUSBD.inf and PALMUSBD.sys) I can then SYNC with Outlook 2003
Sep 11, 2005 | Handspring Visor Deluxe Handheld
Cannot SYNC Outlook Calendar and Contacts
Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
Sep 11, 2005 | Palm IIIc Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
LG KU990 Viewty Logo
27 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
