Question about ViewSonic Computers & Internet
I have viewsonic 2230wm screen and it has gone white Put another screen onto PC it is ok , so fault with monitor
    Novelist:
    Scholar:
  • 96 Answers
Check video cable to ensure all pins are straight. If the cable is detachable, try a different video cable.
Check the OSD menu settings (contrast, brightness, color adjustments). use the reset option to reset the monitor back to factory settings.
Check the user's guide to see if any special conversion connector or adapter is required for proper signal continuity between your specific video card and your model of LCD.
If that doesn't work, you have pretty much exhausted the things a user can do with it. here is the support contact form for Viewsonic: http://www.nohold.net/noHoldCust18/Prod_4/KnowledgePortal/KPScripts/Route.asp?RouteID=28&surveytype=4
Posted on Jul 14, 2008
My ViewSonic 2230wm made a loud noise as it flicked once and shut off forever.
Getting the parts needed and repairing this monitor would probably not be cost effective. If nothing happens when you try to turn it on (i.e. no lights or LEDs come on) then it probably is the power suppley circuitry that is failing. If you are technically capable, you could remove the covers and look for a blown capacitor (the loud bang sounds like a capacitor).
Feb 12, 2014 | ViewSonic Computers & Internet
VIEWSONIC GT775 PROBLEM
Hi no sorry their is nothing you can do it would cost to much to replace the screen you are better of replacing with a new one not alot of places do this sort of repair as it costs more than a new one this problem is not an eays fix it just costs to much to replace the lcd screen let me know if you need further assistance ok
Mar 08, 2008 | ViewSonic VX924 19" LCD Monitor
VX924 (Silver, Black) 19" LCD Monitor: monitor has suddenly gone white...
My VX924 did the same thing but now displays nothing and power switch light just blinks. According to an answer listed on previous page, it may have bad capacitors. I may have to take a look at them. Viewsonic repair facility examination of this monitor runs $70.
May 17, 2010 | ViewSonic VX924 19" LCD Monitor
Viewsonic ve150m problem white screen
Are you still using the same computer that was set to 200Hz? If so, start Windoze in safe mode and reset the display properties to 1024 x 768 60Hz. Reboot the computer and everything should be OK.
Does this model use an external ac adapter or an internal power supply? Twice I have seen a white screen caused by bad capacitors in the power supply. They may look good, but you should replace them anyway. Look in the 2ndary circuit of the power supply, you should see some capacitors that are (for example) 220uF 16 to 25V, 470uF 16 to 25V, 1000 uF 16 to 25V (all those capacitors could be 16V or 25V). Replace them and try the monitor again.
If it uses an ac adapter, try a different 12V adapter. Make sure it has the same or higher amperage rating. If you can't find one, you will have to measure the power going onto the board inside the unit while the adapter is plugged in and the monitor turned on. If it is less than 12V you need a new adapter.
If none of this helps, the panel or main board may be damaged. In most cases these two parts cannot be repaired.
Jan 22, 2009 | Epson Viewsonic ViewPanel VE150M Monitor
In game border issues
Hi...there,
It's seems you've got a busted panel...but send me the screen shots anyways... to this address @ cjt@3rd-rocks.com
Nov 28, 2008 | ViewSonic Computers & Internet
I BOUGHT A VIEWSONIC FLAT SCREEN ALMOST ONE YR AGO.i WAS ON COMPUTER,LEFT IT FOR A FEW MINUTES TO COME BACK TO A SOLID WHITE SCREEN! WILL NOT SHOW ANYTHING.tRIED IT ON ANOTHER COMP AND WORKED FINE? hOW CAN...
try to borrow a monitor and have it installed on your PC, then set the display settings to 1024 x 768 pixels then apply it, remove the monitor and put back your viewsonic flat screen.
have a nice day!!
allen
Jun 26, 2008 | Computers & Internet
Viewsonic E70 - Menu Popup
This is a builti n feature on the monitor of course- not PC driven
A repair is not likely
Buy a nice new Flat screen
Oct 25, 2007 | ViewSonic E70 17" CRT Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
Computers & Internet Logo
280 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
