My computer cannot detect my USB pen drive. It was working fine this afternoon. I have tried switching ports and tried different computers. I think its due to rough handling. The make is 'smart', if it helps. I was just wondering if you could guide me to dismantle it and fix it. I have a spare USB cable! Thanks. All the stuff in there is very very important.
  • 1 more comment
  • Derek Scott Jan 14, 2009
    yesterday everything was sweet. today i put the drive in, comes up with a new drive letter, but each time i click on it it says to insert disk. the drive name that i named it no longer exists and it reads full with 0 bytes. I have everything from old photos to housing contracts. i was going to back it up again but kept putting it off. help! I need the data back! If recovery programs are no good are there any companies that can repair it?
    Thanks
  • aksta May 06, 2009
    My computer did not detect the pen drive.
  • sranjancs May 11, 2010
    i have same problem.. how to solve this??
    Scholar:
  • 51 Answers
Sadly, if your computer is not recognizing the USB flash/pen drive at all when you plug it in then it's one of a couple of possible problems which can be separated into 2 distinct groups.
1) problems with your computer
--you said you tried multiple computers, and it would not recognize on any of them. i'm assuming they are systems which this or a similar drive has worked on before. therefore, it's 90% certain that there is NOT a computer configuration problem.
2) problems with the drive
--if the drive is being recognized by the computer, and you just can't retrieve the data on the drive then there's a couple of possible solutions. Tech Republic offers free membership and several "free to try" programs that could help recover the data on your drive. Click here for a link to Tech Republic
--If the drive is not being recognized by your system, then it is most likely physically damaged and there is not a high probability of recovery. If the connector is bent at all you could try straightening it out, but other than that there's not much you can do to recover your drive.
I hope my solution answered your question or helped out in some way. Please do not forget to rate my solution.
Posted on Jul 14, 2008
My transcend 2 GB pen drive is not detected in windows xp?please reply me how i solve this problem.
Try connecting your pendrive in some other computer and if not working in different machines also, then the problem is with your pen drive. If genuine transcend pen drive, then claim it under warranty to get the new one.
If working in other computers but not with your computer, then try connecting the drive to your computer via the USB ports directly available behind your computer as this may fix the issues with USB extension cables and usb spliters, if any
I hope this is helpful to you
Thanks
Sep 06, 2010 | Computers & Internet
Pen drive not detected on any pc
Hi
First of all try in different USB port and check whether it is working . If still it is not working , then you need to check whether USB port is blocked .Right click on the my computer and then select tab hardware in that click device manager in that you can find USB controller in that you can find the status of USB port .
Hope this helps .
May 28, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Apr 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pen drive is not detecting
1. Connect your pen drive to some other USB ports present at the rear side of your desktop pc.
2. In case of laptop, try connecting to some other available usb ports and check
3. In still not detected, then test your pen drive in some other systems.
4. If still not working, then it implies that your pen drive got detects.
5. If your pen drive is original kingston then you can claim the warranty from the place where you got it.
I hope this information is helpful for you
Thanks
Mar 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Prin problem
first check usb port is working or not in computer using any usb device ..... insert another usb device like pen drive and usb mouse ....if its detecting and working fine means no issue .... take a new printer cable and check its detecting or not if its not working its may be issue with the printer usb connector .....if your computer usb not working try fix it ...... if
Dec 12, 2009 | HP LaserJet 2840 Printer
Sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Pen drive is not detected by the Pc
go to my computer property then hardware then device manager then uninstall usb drivers then right click any driver and clik on scan for hardware then it install automatic usb drivers.
then restart computer then connect pen drive to computer then check if still face problem try all usb port of computer.
also check your usb port of computer are working fine.
Thanks for using fixya.
Please rate solution if it helps you.
Jul 23, 2009 | Electronics - Others
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Jul 15, 2009 | Iomega REV ATAPI HDR B/U KIT CA 6 REV...
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
