Question about Kenmore 24 in. 15199 / 15194 / 15192 Built-in Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Maytag dishwasher quiet series 400 Model MDB7601AWW. Dishes have hard, stuck on grit and food particles, after rinsed and dried. This came up all of a sudden after running fine for two years. I have done all of the troubleshooting solutions like checking water temperatures, etc. The top rack seems to be the worst. Please give me some ideas of what else to try. I'm having to soak and wash dishes twice, help!
  • 1 more comment
  • dhj42 Sep 14, 2008
    Same here, although we only lasted about 6 weeks before experiencing stuck on grit, but most times the dishes came out fine...now it is grit all the time.
    Is there a 'water saver' restrictor somewhere in the plumbing? We are on a well but we have lots of pressure.
    Same problem after 6 weeks of use. Intermittent at first now we have dried on grit every time.
    Is there a 'water saver' restrictor in the plumbing. We are on well and septic and even though we have lots of pressure I wonder if it is not getting enough water during the rinse cycle.
  • Anonymous Feb 26, 2009
    me too. 1 year of use.
4 Suggested Answers
  • 31 Answers
SOURCE: Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Posted on Mar 14, 2009
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
heatman101
  • 43501 Answers
SOURCE: dishes on top rack always have food particles on
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2011
There is food and grit stuck to my glasses. Where is this coming from? I am rinsing all the dishes before I put them in , so it must be in the dishwasher somewhere,
We used to have this problem with a Kenmore that had a built-in "garbage disposal"--it was a little blade that ground up larger food particles. Occasionally a cherry or olive pit would get inside and dull, chip or break the blade, and the symptom was food particles on the dishes. The solution was to replace the grinder.
Jul 26, 2011 | Frigidaire Professional Series 24 in....
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Not draining. fills, then smells Maytag quiet series, 100
there is clog in your main drainage line, you are smelling the decay of your food, rinse off your dishes before placing them in the dishwasher
Jul 22, 2010 | Maytag MDB5100A Dishwasher
Grit on clean dishes.
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jul 18, 2010 | Maytag 24 in. MDBH940AWS Built-in...
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
May 16, 2010 | Maytag 24 in. MDBH970AWS Built-in...
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
Food particles and spots on dishes
Are the holes in the spray arms clogged? That will cause it and they're not too hard to clean out.
Dec 12, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Mar 14, 2009 | Dishwashers
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 | Dishwashers
Open Questions:
Kenmore 24 in. 15199 / 15194 / 15192 Built-in Dishwasher Logo
613 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
