Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash HE41
Washer will not complete cycle, display indicates F-11, DL, I have lost the owners manual and don't want to call for service if can be fixed on my own
The manual says that there is a communication problem between the Central Control unit and the Motor Control unit. It says to check these things:
1. Check wiring harness connections to the MCU, the motor, and CCU.
2. Check the Drive system for any worn or failed components.
3. Check Motor
4. Check that the MCU and the CCU are not mounted upside down. The wires should
be to the left when facing the MCU connectors.
Posted on Jul 27, 2008
What might be causing the intermittent F-11 codes on a Kenmore Smartwash front loading washer?
f11 error is communication error.most likely bad solder joints in ccu or mcu.
May 08, 2017 | Kenmore Washing Machines
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
I want to be able to read the Owner's/Instruction Manual for Kenmore Elite HE41 Front loading washing machine on line. Where?
Go to managemylife.com and enter your complete MODEL NUMBER (located on a nameplate around the door opening) under their "Manuals" link at the top of the page. The owner's manual and installation manual should be available in .pdf format and can be downloaded or printed for FREE. I hope this helps you.
Apr 18, 2011 | Kenmore Washing Machines
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE4 has fault code of dl and F?
F-DL code is for your washer and if the main control has not been replaced then that is what I would replace most of the time F-DL is also seen with a F-11 code later in the cycle, i am sure you hear the washer try to lock the door a few times and pop up F-DL. the main control part # is based off of the model#
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Smartwash Quietpak4 won't turn back on
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite will not resume cycle
need more information any error code or stopped at 11 minutes/ possible f/11, dl/f its ccu board top in back
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
495 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
