New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
