Question about Whirlpool ED2FHSS Side by Side Refrigerator
Hot refrigerator Wall between freezer and refrigerator very hot.
  • 410 Answers
You need to check the condenser fan motor located in back of the refrig behind cardboard cover. most likely the motor is bad or something is obstructing the fan from turning. also be sure the coil under the unit is clean as well. temporarily you can place a house fan blowing in the rear of the unit to keep it operating normally until you get it repaired.. peyton
Posted on Jan 20, 2009
Freezer not working, fridge is fine.
That seem to me like it could bea simple cleaning. Dust and junk gets into the condenser. Blow that ****** out and party on. I have your models service manual on my foggy blog
Mar 05, 2012 | GE GSS25LGM Side by Side Refrigerator
Whirlpool ed22dq wall too hot - center wall heats up and frig temps is going up yet no defrost in freezer.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
May 03, 2011 | Refrigerators
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Side by side refrigerator model # 51562103 center wall - very hot
if fridge and freezer temps are normal, what on earth is your problem?
Nov 14, 2008 | Kenmore Refrigerators
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
452 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
