Question about Brother LS-1217 Mechanical Sewing Machine
Feed Dog I have a singer quantum futura ce200, and the first thing is when I move the feed dog switch from left or to right the feed dog does not go up or come down I have to reach in with my fingers and manually pull it up. I haven't found anything in the manual for it. And it is my first time w/ this machine, but I do believe it is suppose to move it up or down (for darning or sewing). And the fabric wasn't advancing so I had to pull the feed dog up, and it doesn't seem to work as well as when I was first using it. The second problem I am having (don't know if they're related) is, as I am sewing it will beep and I have to pick my foot up and start again. It will beep like every 10 stitches. the threading is correct, no needle broken, and it sews fine, however, it continues to beep throughout the project.
5 Suggested Answers
SOURCE: Bobbin Case Slipping
I have found that this usually starts with the top thread somehow getting stuck - either in the tension control, or wrapped around the post. Generally, this pulls the bobbin case out of alignment, and the needle hits it. If the needle hits in just the right/wrong place, it can gouge the bobbin case, making a rough spot or hook that will catch the thread, causing the problem to repeat more often, and without any apparent cause. If the nicks and gouges are not too bad, I have been able to file them down, or use a pair of scissors to scrape any protruding bits off. If there are too many gouges, or they are too deep for this to work, you need a new bobbin case. I have purchased them from sewvacdirect.com for $20-30, plus shipping.
Posted on Sep 19, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: feed dog & beeping
To make the feed dogs come up ... turn your wheel about 2 times all the way and they will come up (this is after you switch the feed dog switch to the up position)
Posted on Jan 24, 2010
  • 64 Answers
SOURCE: what embroidery download formats can be used on singer ce200
It depends on your software version. The list of supported formats could be found in the manual, on Futura support site or checked right through the sofware menu (File->Open, File->Save as)
Posted on May 02, 2010
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
Posted on May 27, 2010
How do you know when the feeder dogs are up and down for futura 250
you can see the feed dogs in the needle plate area and be able to feel them with your finger
and the machine will sew a straight stitch when the feed dogs are in the up sewing position
if the feed dogs are down then the machine will not sew only stay in one position
Oct 09, 2013 | Singer CE-200 Quantum Futura Computerized...
Should I oil singer xl, nothing in instruction manual
contact singer customer service about oiling, some machine are
self oiling, since the feed dog is up and not feeding the fabic
then the machine needs to be checked to see what wrong with the
feed dogs.
Mar 19, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
I have a futura ce150 and the feed dog is raised but not moving the fabric
Try lowering the feed dog and then raising it again, but be sure to push the switch over as far as possible. Sometimes the switch will stop just a little short and the feed dog will not be 100% raised but it will seem to be to the naked eye. Hope this helps.
Feb 27, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a futura CE-200. The feed dog is stuck in the down position. The switch will not work. Is this something that I can fix?
I had the same problem with my Singer machine. The lady in Hancocks told me that when you begin sewing the feed dogs will pop back up. Just rotate your wheel and see if that fixes it.
Sep 25, 2010 | Singer CE-200 Quantum Futura Computerized...
What embroidery download formats can be used on singer ce200
Apr 28, 2010 | Singer CE-200 Quantum Futura Computerized...
Machine will only work in reverse
If it is like one of the machines I have, you can set it to do mending and embroidery so that the feed dogs to not advance the material. If so, there should be a dial that allows you to re-set it so the feed dogs are not depressed. Hope this helps.
Mar 18, 2009 | Singer CE-200 Quantum Futura Computerized...
Feed dog & beeping
Jul 14, 2008 | Singer CE-200 Quantum Futura Computerized...
Brother LS-1217 Mechanical Sewing Machine Logo
42 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
