Question about Oster 76076-040 Hair Trimmer
Oster clippers My wife took the clippers apart to replace the blade but was unable to put it back together again. I look at several diagrams but i have to admitt I am unable to get the blades back on this clipper. Oster Golden A-5
  • 5 more comments
  • Anonymous Aug 11, 2008
    cannot attach/affix #10 blade to oster A5 two speed
  • tempielaw Mar 11, 2009
    I cannot figure out how to put a set of older oster clipper blades back on after they were taken apart to be cleaned. (oster 96-01e). There is a large blade, a smaller blade, a bracket and a piece that clips into the clipper.
    Can you tell me the order the go back together?
  • Anonymous Mar 14, 2014
    plastic head part that holds blade
  • Anonymous Mar 16, 2014
    put new blade on agc clippers
    Recently changed the brushes, had the blades sharpened but now gets hot when clipping.
  • Anonymous Mar 30, 2014
    how do I put on a clipper blade?
    Clipper for large animals
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Posted on Jul 15, 2008
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I took my oster trimmers apart now i dont know how to put them back together can u help me
Unfortunately, Oster does not publish any real maintenance manuals. Basically, if you only took apart the cutting blades and the oscillator, it's not too hard. If you tried to take apart the electric motor, that's a whole different story. If it's just the blade assembly, carefully align the blade assembly with the groove pointing into the trimmer handle and hold the blades together so that they are parallel, not crooked and reinsert the screws. You will see how the blades align, based on the wear marks on the bottom blade guide. If you took apart the oscillating arm, then line up the cam pin with the round hole in the arm, then replace the screws that attach the top blade to the oscillating arm. You may have to push in the tension arm so that you can align the screws with the threaded holes on the handle first. Final step is to screw the bottom blade guide back onto the handle, again align the guide with the blades so that they are parallel and not crooked. The best way to do this is to start threading the screws, then before tightening them all the way, align the blades first. If none of this works, go to this website: http://www.osterstyle.com/CustomerService.aspx and locate an authorized Oster dealer/support center near you. You'll probably have to mail the clippers in to one of the sites.
JB
Feb 25, 2011 | Oster T-Finisher 76059-010 / 76059-030...
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Took oster blades apart and now don't know how to put them togeth
First thing about Detachable clipper blade are Tension and straightness, You need a special tool to set the tension on your blade and the spec's on how much tension, plus you need to set the straightness of the tension spring. With out these tools your blade will not cut, even if some body sharpens the blade and do not set the tension correctly and straightness. You need to send it to a professional sharpening company, mannyssharpening.com has a mail order service he charges $8.00 to sharpen set to factory spec's and this price includes return shipping, they are fast in service.
Mar 26, 2010 | Oster 76076-010 Hair Trimmer
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-040 Hair Trimmer Logo
962 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
