Question about Mitsubishi WS-65819 TV
Ws-65819 Upside blue arch extending from top of TV screen
Is it a convergence problem and what part do I replace and is there a Mitsubishi part dealer near my zip code (78154) Schertz, TX. (in San Antonio area metroplex). 2109458344 home phone or e-mail Thanks Guru!
Used your info to isolate and verify trouble with the upside blue arch. It was a convergence trouble. Then hired tech from your site recommendation to come out and fix today. He replaced both convergence chips and cleaned electronics. Works like new. Thanks for your help but you should allow customers a one time view-to-trouble search that I think would build a you a solid following. Folks would recognize your site as good source to search when trouble strikes and be more likely to subscribe. It gave me a good sounding benchmark but it could be enhanced. Thanks!
David Herrera
Posted on Jul 15, 2008
My Mitsubishi ws-65819 shows in an oval shape, can this be fixed, also is there a way i can do it myself to save some money? Also how to play an Xbox 360 in HD? can rplace the convergence ic's on convergence module......these are the big stk type ic's and also the low ohm resistors.
These are 3.9 to 6.8 ohm half watt on the yoke return circuit. Let me know how you fare......regards. meder's tv
May 28, 2012 | Mitsubishi WS-65819 TV
Mitusbishi Model ws-65819 color convergence repair. How does one go about fixing it?
The two stk-392=570 chips need to both be replaced===they are along with the rest of the circuit on the middle board.
May 20, 2012 | Mitsubishi WS-65819 TV
Have a Mitsubishi WS-65819 (about 9 yrs). over past 3-4 weeks the color started to skew (3D like arch on top and bottom), then yesterday, the TV totally powered down and will not power up, totally dead. ...
You lost your convergence IC's and possibly a resister or two that are in the same circuit. If you are good at Soldering, this should be somewhat of an easy fix. I believe you can still get the IC's for this set.
Aug 09, 2011 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819__Convergence bows at top and bottom of the screen. Pops in and out and if I take off the front speaker grills and Picture tube cover and place a fan in front of it to keep it cool, it...
Correct, convergence output chips are getting heated and causing problem. Replace them to solve tv issue.
Also check dry solder connection nearby these chips, resoldering these solder connections will cure dry solder joints problem as well.
Dec 24, 2010 | Mitsubishi WS-65819 TV
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
My WS-65819 won't power on. It would power on for
need to replace the stk's and some other caps, usually have to resolder the chasis on both convergence and power supply chassis.
Dec 03, 2009 | Mitsubishi WS-65819 TV
Screen is arching at bottom of screen. only does when you first turn it on after 10 0r 15 minutes it fixes itself
This is the begining of a convergence problem and the O/p IC' will probably need replacing.
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
Convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Oct 06, 2009 | Mitsubishi WS-65819 TV
Can't aline the vertical red and blue on the left
The Convergence circuit has failed. It is recommended that a professional do the job.
The Convergence IC's need to be replaced.
It will be a STK393-110 or a pair of STK392-570's.
Hope this helps,
Jul 16, 2009 | Mitsubishi WS-65819 TV
3 colors on TV
It sounds like we had the same problem. Our TV is the same make and model also about 6 yrs. I went to the Mitsubishi website and was able to find a service company in my area. It turned out to be the convergence amplifier. In the end we replaced a pair of convergence amplifiers and he also soldered the pins. (in home) The cost of the repair was $375, much less than purchasing a new TV. I realize I was no help in locating the amplifiers for you but maybe if you call a service company in your area they can help you with their location inside. Hope I was of some help.
Mar 22, 2008 | Mitsubishi WS-65819 TV
Intermittent convergence issue became permanent
Hi Ed,
Your convergence amplifiers are definitely bad. The user manual will not work, since it is the same manual that comes with the set when it was new. The service manual can be found at:
Best Regards,
P.S. Thanks in advance for rating me!
Feb 09, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-65819 TV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
