Question about NEC Computers & Internet
My cpu screen keeps going from full screen to half screen can hit select button then exit button then screen goes full screen but has a 1 inch black line on right side
  • Bob Duker May 11, 2010
    This is your monitor going half screen? And what do you mean by half screen? Does the screen move over to one side and only fill half the screen?
  • 3 Answers
How do u change resolutions on screen as i am not sure how to
Posted on Aug 19, 2008
  • 177 Answers
Check your resolution on your screen and then try various settings to see which one is least problematic.
Posted on Jul 14, 2008
Hi WITH THE ZEBRA DESIGNER I SETUP MY S4M FOR A 4X 6 INCH LONG LABEL THERMAL DIRECT BUT PRINTING STARTS ON THE MIDDLE OF THE LABEL AND GOES OVER THE NEXT LABEL TRIED TO CALIBRATE VIA SOFTWARE BUT WAS...
This will make your printer feed out 2-3 labels each time it is turned on or the head is closed to determine the label length.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of NO MOTION (if not, repeat previous steps)
Hit the + sign until you get to CALIBRATION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT (twice) to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Jun 08, 2011 | Zebra S4M Thermal Label Printer
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
My acer netbook starts and you can see the screen works but couple seconds later it just turns black. Can anyone tell me why its doing that?
It appears that Operating system is failing to load. Try the steps below:
1. Turn Off the computer
2. As soon as you power button to turn ON the computer keep on tapping the F8 key, it will boot to Advance boot menu,
3. Select Safemode with the help of Down arrow keys and hit Enter
4. If the computer is booting to Safemode then there is no hardware failure, you can try full system restore.
To do a full system restore, please follow the below mentioned steps:
2. As soon as you hit the power button keep on holding the Alt key and keep on tapping the F10 key ie Alt+F10
3. It will boot to Acer Recovery Console
4. Select Full System restore and follow the on screen instruction
NOTE: This is erase everything from the computer including any data; pictures or music
Thanks and regards,
Anil.B.R
Nov 23, 2010 | Computers & Internet
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
The picture on my Compaq monitor shifted 1 inch to the left. There is a one inch black space on the right side. I have a HP Compaq d530 CMT
click menu button on monitor. you will see a series of Icons (or scroll through a series of Icons) and one will be a square with a smaller square inside it that is half inside the larger and half out. Navigate to that Icon. Use the + or - buttons to move the screen in either direction until it evens out. Use + or - button to navigate back to exit and and then press menu button to exit screen. Or, sometimes you simply push the menu button a second time. These 3 buttons will be on the bottom front of the monitor. Good luck
Oct 21, 2010 | HP Compaq d530 CMT Intel Desktop PC -...
Keeps showing 'add ink' after adding inks & turning off/on again
This method was for 8500/8550, but we have a 8560mfp and it worked for us (with some slight modifications...). Skip step #1 and do this instead to get to the Diagnostic Menu
Click the "System" button. Select "Information", then "Troubleshooting" then "Service Tools", and finally "Enter Diagnostic Mode".
"OK" below means the check mark button on our printer.
"This may include: Low ink error, add ink error or 09,035. Error codes and more.
1) Press and hold the red button (info button) and the "OK" button simultaneously. This should take you into the Service Tools menu.
2) When in the Service Tools menu, scroll down to the "Enter Diagnostics" menu. Select the "OK" button. It will go through some cycling at this time for about 2 minutes. The screen may go blank a few times too.
3) It then asks for a confirmation, select "ok" again. The printer will go through a minute of rebooting. The screen may go blank a few times too. You are waiting for the diagnostic menu with the Test #00 "no test selected"
4) At this point hit the down arrow button until you reach the test #76. Select "OK"
5) It will ask for a confirmation. Select "OK" to confirm.
6) Then hit the down arrow button again and select the next test #75. Select "OK"
7) It will ask for a confirmation. Select "OK" to confirm.
8) Then hit the up arrow until you go over test 100 to test 01. "Exit diagnostics."Select "OK".
9) It will ask for a confirmation. Select "OK" to confirm.
10) At this time the printer will again reboot for several minutes
Oct 13, 2010 | Xerox Phaser 8560MFP Laser Printer
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit SELECT
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SET/UP EXIT to save changes (permanently)
Sep 20, 2010 | Zebra Stripe S400 Label Printer
How to reset zebra z4mplus dt printer setting
Factory Reset
Press Setup/Exit - 2 Times
Press '+' - 3 Times
Press 'Select' - 1 time
Jul 14, 2010 | Zebra Z4Mplus Label Printer
Black rectangle on bottom half of screen
The "Caption" mode may be on and set to "Text". To fix press MENU button on the remote then use down arrow to select "Setup" and press ENTER. Select "Caption" and press ENTER. Select "Off" and press ENTER. Press MENU again to exit setup.
May 09, 2009 | Televison & Video
Black Screen
DISPLAY HAS POBABLY WENT BAD.
BUT THE WAY TO MAKE SURE IS TO CONNECT YOUR COMPUTER TO A DIFFERENT MONITOR TO SEE IF YOU GET THE SAME RESULT
Jan 16, 2008 | Sony VAIO VGC-V617G PC Desktop
Computers & Internet Logo
104 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
