Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
can't get out EXCH mode .Can't press any buttons.
I no longer have instructions for changing VAT rate for DR-120TE
Can you help please
I have lost instruction for changing VAT rate on Casio DR 120TE can you help please
