Based on your description of the breakers you should have 230VAC to the pump motor. Even if it is only 115VAC you should still get a response from the unit when powered on. A 230-connected motor will run on 115 for some time but will overheat and eventually fail. If you are getting nothing you have issues with the power as well as the pump. Get the $40-$50 multimeter and check your line voltages to ground and line-to-line. You will find a problem somewhere.
And to answer your other question...yes, connecting 230VAC to a motor setup for 115 will burn up the winding.
John
