Question about Vacuums
Elec. cord gets hot - Vacuums
Got a new one!
Thanks
pepajeff
Posted on Jul 18, 2008
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Why does the plug get hot when the heater is on
Sometimes the electric cord isn't made to handle the wattage of your heater....either change the cord or use a heavier extension cord.
Nov 16, 2014 | Vacuums
My shark professional steamer plug gets extremely hot. Is that normal?
no it should not get hot undo the plug and check if the wirers are conected tight one of the main causes is loose wires, have you tried a differant outlet.
Jan 22, 2013 | Vacuums
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Nopower cannotlocatefuse kenmorecannistervacuum
id check to make sure cord or switch isn't faulty first with an elec meter. if they are both good usually the fuse's are located in the top casing at bottom.
Jan 08, 2013 | Kenmore Progressive Bagless Upright with...
Does not run at all when pluged in and turned on
first i would check to make sure the outlet you are plugged into has power. a simple elec meter that can read 200v or higher should work.
if that is not the problem then its either your vac elec cord or the switch. if it was your motor you'd a probably smelt or heard something before it would not turn on. hope this helps.
Nov 26, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Why is it important that the resistance of an extension cord be small when it is used to power an electric heater?
Hi pipay thinti...
You must have little resistance (large wire) in the electrical cord because you want the elements of the heater to heat up and not the cord...if you had high resistance in the cord it would get too hot and melt the plastic coatings.
Please take time to rate me
Jul 26, 2011 | Vacuums
Dyson 07 plug gets very hot after prolonged vacuuming
Electrical current passes through the electric cord and plug - it will get warm, that's normal. If the problem is worse where you smell an electrical burning smell, only an authorized dealer can fit a new power cord to your vacuum cleaner. Call the Dyson helpline, they will let you know who the closest repair dealer in your area is.
Jul 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a d4c rainbow vacuum, need help replacing the electrical cord
you have to splice them. Use crimp-on wire connectors (best), or threaded twist-on wire connectors. Do NOT just twist wire strands together and tape wires without using wire connectors . . . that is a NO-NO.
Jun 02, 2009 | Rainbow 75th Anniversary Canister Vacuum
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
