SOURCE: Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: Self-propel switch arm broke off where control
Greetings from GoVacuum,
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
We have also put together a very helpful video for your vacuum cleaner on how to replace the belts. The belts on this model are also a frequent issue we see with these self-propelled Winddtunnels. In fact, for best results you should change the belts once a year, even if they are not broken, because they do heat up and stretch to a point where they don't work as well as a new belt would. The video also explains how you can maintain the roller brush will help you get the longest life possible out of your belts.
Video Repair on How To Replace The Belts Hoover Windtunnel Self-Propelled;
I hope that this information was helpful to you in repairing your Hoover. If you did find this helpful, may you please rate the repair by clicking the the Thumbs Up Icons in the top right hand corner of this repair to help me start out here on Fixya? I really do appreciate it, thank you so much!
Feel free to request a repair clarification if you have any questions or concerns you'd like to address.
Chris J.
GoVacuum
SOURCE: self propel unit broken
