Question about Frigidaire Kitchen Ranges
HAVE GALLEY SERIES SMOOTH TOP STOVE/OVEN THERE IS A WINDOW TO SEE INSIDE OVEN-HOW CAN I CLEAN IT? NOT THE OUTSIDE-NOT THE OVEN SIDE-BUT I HAVE DUST IN BETWEEN OVEN AND OUTSIDE. NOT SURE IF YOU UNDERSTAND-THERE ARE OPEN AREAS ON TOP AND DUST FALLS IN
    Novelist:
  • 161 Answers
This would require that the door be taken apart. If you attempt this make sure you mark all glass as to which side and position any spacers are in. Each piece of glass has a right and wrong side to face out. There can be up to four pieces of glass used. If installed wrong the outside will get hotter than it should. during the clean cycle.
Posted on Jul 15, 2008
What may cause the oven overheating during self clean
well last time I checked the self clean went to around 600 degrees . has to to burn off the stuff burnt on inside . and YES outside gets really hot .
Aug 28, 2014 | General Electric Ge Stove / Oven / Range...
Kenmore stove
Condensation streaks on an oven door window can be between multiple glass panels such that it is necessary to disassemble the door to clean.
Oct 30, 2013 | Kenmore Kitchen Ranges
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
Yesterday I heard a loud pop from inside the stove. Frigidaire smooth top professional series just about 5 years old. Looked inside and my parchment paper had caught on fire which had never happned before...
Is this an oven or the cook top?
A blown oven element is possible. You may still be able to bake but the oven will seem to take forever to warm up. An easy check would be to crank the heat up full bore and put your hand near the top then the bottom. You should feel more intense heat the nearer you get to a working element.
May 08, 2009 | Kitchen Ranges
My smooth top burner will not work
The #1 most likely problem is that you don't have 240 volts to the unit. Your clock and lights will come on but not the burners or the oven elements. Turn off your breaker and then back on. If this doesn't correct the issue...#2 Check your cord and the terminal where it attaches to the stove for a burnt connection, WITH THE POWER OFF!!! #3 Call a technician.
Dec 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Lost manual to my electric oven, how do you clean inside of oven?
just input your model number here for a copy of the manual, located onthe inside of the oven door, or perhaps the side of the storage drawer.
Nov 23, 2008 | Kitchen Ranges
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
135 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
