Question about HP DeskJet 950c InkJet Printer
Deskjet 950c my printer either prints double dutch writing instead of what it is supposed to print and when prints correct it only prints half way across the page and the middle light flashes all the time you have to press it to make it print a single page and then it flashes again
    Scholar:
  • 137 Answers
Most likely your encoder has become fogged due to aerosol in the printer. You can carefully clean this following the instructions here. Be sure to heed the warnings, the encoder is fragile and can be easily damaged.
Once you have cleaned the encoder force an alignment calibration, either from the toolbox of alternately turn on the printer, then press and hold the power button, then quickly press the formfeed buttion three times, then release the power button. If the alignment fails you may need to lean the bottom of the alignment sensor, it is located in a small black package just on the lower right side of the carriage. Open the lid, allow the carriage to move to the center then clean the sensor from below with a damp q-tip.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 14, 2008
Printing Margins settings incorrect with Windows 7
if the printer have disk use it and install printer driver
Dec 21, 2013 | HP DeskJet 950c InkJet Printer
Hp deskjet 950c
It is a problem with the mechanic.
Jul 16, 2008 | HP DeskJet 950c InkJet Printer
My deskjet 950C printer will not print out anything exept the test sheet. everything just goes in a queue. what should i do? Please get back to me as soon as possible, Thank you.
If it will only print the test sheet the printer is not seeing the computer. Check your cable connections and your drivers. Try another USB port on the computer. Go to 'Printers and Faxes' and see if your printer is listed there, if not, install it using the software supplied or look for it in the Windows list. You can also try access the Printer Assistant which comes with HP products and should be there it the software is correctly installed. There is help and support in that as well.
Apr 24, 2011 | HP DeskJet 950c InkJet Printer
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
HP Deskjet 950c won't print black
You might be able to use a q-tip with alcohol or acetone to loosen and clean residual ink from the inside and bottom of the black printer cartridge tray--I've even had to use compressed air after loosening the junk after my HP sat for a year. Btw, I'm sure you know this, but the contact pads need to be clean and free of factory tape. I hope this helps.
Feb 22, 2010 | HP DeskJet 950c InkJet Printer
HP Deskjet 950C. Printing is coming out with one
1.driver problem
2.their may not be enough toner
3.virus in system
try to solve above may give the solution
Aug 31, 2009 | Office Equipment & Supplies
Print is too small.
r u printing from internet...? if yes then save the document before you print on your desktop or copy the document on word and then print.
Nov 28, 2008 | HP DeskJet 950c InkJet Printer
Printer refuses to print Error Message
i suggest you inspect the bottom, to see if anything is compromising the connection pad.
Feb 27, 2008 | HP DeskJet 950c InkJet Printer
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
HP DeskJet 950c InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
