Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
Panasonic 27 inch TV Model CT-2701G bui...
By bwwolf on Jul 14, 2008
I have 19 real thin horizontal lines across the top 4 inches of the screen. It looks like I'd need to remove the back, I don't see any holes or any thing to adjust. Is it something that can be corrected through the remote. Lost
Solution #1
posted on Jul 14, 2008
Not Rated)
Basti
Rank: Wiz
Rating: 85%, 816 votes
Hi-
Try removing and reinstalling the cables from the back of your TV.
Keep us posted, thanks for using Fixya!
Solution #2
Not Rated)
sweet_rascal
Rank: Wiz
Rating: 81%, 764 votes
Take out the comb filter and replace the surface mount electrolytic capacitors (I think there were around 4 of them) on the comb filter and put it back in the motherboard.
Replace the electrolytic capacitors in the power supply section.
start with replacing (2) 860uf 180v caps just after the bridge rectifier and continue along the circuit.
Some (15) or so capacitors later, it will finally clear the the horizontal bars and lines
thank you sir
dont forget to rate the solution
have a great day
Solution #3
Not Rated)
Yazz226
Rank: Guru
Rating: 86%, 232 votes
yes u will hav to..i suggest you get professional help...u cud use up the warranty if ur tv is still under that period.
Thanks for using Fixya
Solution #4
Not Rated)
Jaime867
Rank: Guru
Rating: 88%, 966 votes
I've answered your question already. Click here.
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
horizontal rolling of picture and shut down for a few minutes
Answer
phillips model 19pfls422d/27 power light turns blue screem seems to turn blue no image on screem
Answer
Was watching the TV and it shut off. Not audio and no screen after that. Red LED blinks 8 times.
Answer
Panasonic PT-47WX53, Would replacing the convergence ICs STK392-110 incorrectly make it so that the... (More)
Answer
I have a 55inch sd-p55a3-k-kc.when I turn tv on, the power light turns from red to green for a split... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
