Question about Canon PIXMA MP150 All-In-One InkJet Printer
Pixma printer I had alot of problems trying to replace new ink cartridges- I have the right ones but after much difficulty, I got the ink refills in and now there is some black "belt" of some kind hanging behind the place where the ink goes? I can't get the printer to work because of that pulley or whatever that black thing is- HELPPPPPPPPPPPPPPPP
  • Anonymous Aug 24, 2008
    When you replace the ink cartridge you are to click on the black or color one that you replace when i do that it still show that my ink is low or i have no ink . Thank
  • Anonymous Dec 05, 2008
    cartridges chmbar
    Scholar:
  • 99 Answers
That black thing is the drive belt for the print cartridges. It man have come off when you were playing with the cartridges, or you may have a broken part that let the belt drop. Unless you are familiar with printer repair you do not want to open the unit and try to fix it. Take it in to a shop for repair...or you may create more problems than you fix.
However if you want to try use this site to get a guide on howto:
http://www.pdfoo.com/pdf-217/printer.html
Posted on Jul 19, 2008
Canon Pixma mp160 cartridge slams to right side e5 error
you need to replace the cartridge,with a new one original canon,not refill
Mar 03, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
I HAVE A PIXMA MP170 AND THE MESSAGE WASTE INK NEAR FULL, BUT THE MAQCHINE ALSO SHOWS THE CODE 5800 & WILL NOT PRINT PLEASE ADVISE... MANY THANKS
Hi:
The problem here is the waste ink pads are full, these pads are located at the lock posistion to the far right where the units cartridge holder goes when you power down the unit and on start up. The way to solve this to to have the pads replaced, they are used to collect the waste ink the printer uses to clean itself when starting up, These pads usually take a long time to fill up, so either you do alot of printing or you hve used Non Canon inks or generic refill cartridges in the past, these are not good for your printer as some of these types of inks are either to thin or to thick and fill the pads up prematurely..Keep in mind to always use recommended guine ink cartridges you may save a little now with ink refill cartridges but in the long run your printer will eventually give out.
Jul 14, 2010 | Canon PIXMA MP170 All-In-One InkJet...
How do i install new ink cartridges in my mp190
Installing a new cartridge in your computer printer is quite easy. First of all it is recommended that you buy new cartridges every time you run out of ink instead of refilling it. Refilling cartridges will have negative impact not just on the paper but on the printer too. It has been reported that refilled cartridges have ruined many printers. After you buy the new cartridges, remove the old ones carefully.
Remember the printer should be turned off before going any further. Install the new ones in the empty slot and turn on the printer. Remove a test page from the printer and check whether the new inks work or not. The first one or two times the ink might be a little smudge but that's all right. It will become normal again after one or two print outs. If the problem persists, exchange the inks with your retailer.
Feb 19, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer ink
hello laylawoman
if this is the right ink then it seems they do sell refill kits .
canon pixma mp150 ink cartridge and canon pixma mp150 ink refill
i would check on line for better prices .
riz.
Mar 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
141 people viewed this question
old marine
old marine
