Monitor Flashing as soon as the power turns on the icons flash and the entire image looks like its shaking Yes, I have the same problem. CompuMaster 712N, none, I have look for steps online. No one has given a soluation to solve the problem.
    Problem Solver:
  • 6 Answers
My best guess is that the monitor is trying to display outside of it's range. Set the resolution, color depth and refresh rate to the lowest settings and see if you have the same problems. Also, change the cable to a known working cable and keep the length short, like 3' or less. If the image still shakes, then it is an internal problem that would most likely be too expensive to fix.
I assume you know how to change the settings in Windows, but if not post back and I will help.
Posted on Jul 15, 2008
We have a Canon Powershot G12 camera. When taking a picture a red flashing camera appears at the lower left side of screen, the picture comes out white. What do we need to do?
That is the camera shake icon. When you press the shutter button halfway in low light conditions where camera shake is likely, a flashing (g0035839.gif) will appear. You need to change your settings to compensate, usually setting the camera on P or Auto will usually get you an acceptable image. Check the user manual or download it from the Canon website.
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwNDE5MTAx&cmp=ABR&lang=EN
Oct 09, 2014 | Canon Powershot G12 10mp 5x Digital Camera...
Power light flashes continually but monitor will not work. I leave computer on at all times but turn monitor off. I did that last night but today it was flashing and won't come on or off. I tried turning...
Yes. Flashing LED with no image on the screen is the first sign of the power supply gets overloaded. That may be caused by blown/shorted electrolytic capacitors. Open the monitor, take metal lid off and observe for those caps which are rounded on top. Replace them with proper ones.
Sep 11, 2009 | Acer AL1916W 19" LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Monitors goes to sleep when powering my PC
In My Computer, find the icon for Display and configure the energy saving features so that your monitor doesn't sleep as soon.
If you need more help, I will be more than happy to assist.
Apr 07, 2009 | Relisys RLT1720 17" LCD Monitor
I have a sony SLR camera-model DSLR-A300k. The camera shake icon is flashing and the camera will not function. It is turned on and I can see the image on liveview on the LCD screen but cannot use the...
I just took mine to the camera store and the woman at the counter swapped out my lens. The camera now works and the camera shake icon is gone. Try changing the lens, this worked for me and I had the same problem.
Jul 23, 2008 | Sony Alpha DSLR-A100 Digital Camera
Flashing Blue power light
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went black or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 25, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Flashing icon
Low shutter speed icon means that when you take photo the image will be blurry if camera moved.
Is there this icon when flashlight is turned on?
Feb 13, 2008 | Nikon COOLPIX S6 Digital Camera
The screen doesn't display anything and the power button is flashing green
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Nov 30, 2007 | Dell E173FPb 17" TFT LCD Monitor
Flat Panel Monitor the power button flash
Nov 29, 2007 | Dell E173FPb 17" TFT LCD Monitor
Monitor Flashing
Then it goes away? That sounds like the normal degauss feature is working.
Jan 08, 2007 | BenQ P992 19" CRT Monitor
Computers & Internet Logo
612 people viewed this question
David Payne
David Payne
