Question about Maytag Washing Machines
I would like to know the age of my machine, whether I should have it repair or buy a new machine. The model #MAH4000 Maytag Neptune. Lydia Dunbar
  • 5,911 Answers
The age is determined by the SERIAL NUMBER. Please post back with your complete serial number, particularly the last two letter designations. With that info I can tell you month and year the washer was manufactured.
Posted on Jul 14, 2008
On my maytag neptune model # mah4000aww the spin cycle is extremely loud and I recently noticed that midway thru the cylce there must be a leak as a small amount of water is on the floor under the front...
Hello, it sounds like your Neptune's bearings and seal need replaced... See NeptuneBearing for more info on replacing your bearings and renting the special tool kit to save you time.
I see that you have a MAH4000 Neptune. Did you know that your machine shipped with a faulty door latch wax motor that will eventually damage the control board? See NeptuneHelpSong for a video that explains what happens when it fails. You can proactively upgrade your wax motor before it fails and prevent the failure to the control board.
I hope this helps...
Apr 20, 2011 | Maytag Neptune Washer
Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Feb 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Nov 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
I need the capacity for a Maytag Neptune washer Model # MAH4000 AWW
3.5cuFt
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2008 | Washing Machines
Washing Machines Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
