Question about Car Audio & Video
6 cd changer in 2001 ford expediation
I purchased the truck and the cd changer tells me all the cd are bad. I have tried to put a cleaner in it and it want even take it. Should I just purchase another one?
If the unit will not accept or eject any disks, this is a relatively simple fix. Remove the unit from the vehicle. There are 4 T-9 torx screws on the side of the radio. Remove them and slightly lift the CD mechanism from the radio. There are 2 things that need to be unplugged before you can separate the 2 pieces. The 2 wires simply unplug from the bottom of the cd mechanism. The ribbon cable is locked into the socket, you need to grab the lock and gently pull it away from the circuit board. When unlocked the ribbon cable will simply fall out of the socket. Look through the front of the changer mechanism, are there any disks that look out of place? Gently lift the trays to inspect the disks, if one of the disks is too far back you need to get it into place. Reassemble the deck and see what happens.
Posted on Jul 15, 2008
2000 toyota avalon cd player keeps ejecting cd
It sounds like you have dirt stuck on the lazer head. Best way to clean it to get a good "wet head cleaner CD".You may have to run the cleaner several times to get all of the dirt off. P.S. make sure to buy a good cleaner disc, not the dollar store brand.
Mar 21, 2012 | JBL GTO75.4 Car Audio Amplifier
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Part number for a radio amplifier 2005 320e cdi
mercedes Part# A2098200889
for bose systems works with fiberoptic cd changer
Mar 31, 2010 | Car Audio & Video
Where is the amp located for 1997 ford explorer. I am trying to install an aftermarket radio. I have the harness that I need, but where is the amp and the antenna lead tuner box located in the vehicle?
right side above the rear wheel well -you have to remove the panel which has fasteners everywhere and a few screws under the carpet-might have to get a special antenna adapter too- ford premium stereos are weird like that-good luck
Nov 24, 2009 | JBL GTO755.6 Car Audio Amplifier
CAR CD CHANGER - ERROR 3
replace head unit the cost to fix the problem you could but two deck ,use a wiring harness and get the aftermarket mountain kit
Jun 09, 2009 | JBL GTO75.4 Car Audio Amplifier
Factory radio keeps blowing fuses.
you should bypass the factory cd player. I installed a panasonic cd player in a 1994 gs 300 and it was hell. there are alot of wires that have nothing to do with the radio i believe one or some of those wires may be whats causing your problem try this solution if that doesnt work you may have a serious electrical problem
Mar 26, 2008 | Car Audio & Video
Car cd changer
yes. open it up and find the small motor that performs the eject process. Then turn it by hand to eject the magazine.
Jun 13, 2007 | Kenwood KAC-729S Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
