Question about Royal VF1012mx Shredder
MY SHREDDER WORKS BUT WILL NOT SHUT OFF WHEN ON AUTO. THE LASER LIIGHTIS BURNED OUT
    Genius:
  • 1,218 Answers
Try cleaning the eyes first...if that dosnt work and you feel they have to be replaced you can contact Royal at 1-800-524-0799 for parts assistance.
Posted on Jan 17, 2011
SOURCE:
Dm17c will not start when paper inserted. When toggle is turned on I have to then turn off. Auto function is not working.
Sounds like the auto function section of the circuit board is burned out. Below is a link to the manual look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 15, 2014 | Fellowes Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    The automatic-on function will not work
    What model is it? Do any lights come on? All shredders auto shut off after a while.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
    Jul 16, 2009 | Fellowes DM15C Shredder
    Auto Shut off doesn't work anymore
    Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Either of these should be located in the center of the paper throat.
    If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
    Dec 20, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
    Shredder won't shut off after paper goes thru
    Note that the sensors that tells the shredder to stop are underneath the unit.
    Pull out the tray, put the unit on the side and you'll see two places where there are two flat-head phillips screws holding the optical sensors in place (no need to unscrew them). Just wipe the visible part of those two sensors with a rag.
    The sensors that are readily visible on top of the unit tells the shredder when to start.
    Aug 29, 2007 | Fellowes DM15C Shredder
    Paper Shredder will not shut off when in auto mode
    if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
    Jun 14, 2007 | Royal VF1012mx Shredder
    Shredder won't stop when full
    you more than likely have sensors that have burned out this can happen ecspeacially if you leave your shredder in the auto position all the time
    Nov 02, 2005 | Fellowes 220C-2 Shredder
    Royal VF1012mx Shredder Logo
    121 people viewed this question
    Top Royal Office Equipment & Supplies Experts
    James Cagle
    James Cagle
    Marvin
    Marvin
    Adorjani Laszlo
    Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
