Question about Texas Instruments TI-84 Plus Calculator
TI-84 Plus with water damage
Over the weekend I had part of the ceiling collapse in my classroom, soaking three of my TI - 84s. They currently are not working. I'm having a hard time taking them apart to try to dry them out - any suggestions?
Thanks,
Jim
  • 32 Answers
I had the same problem but its best to first just dry it out and with a hair drier at low. Forget about openning it up i couldn't get mine open either. Let it sit for a day and then take the batteries out and press the on button for 30 sec. then take new batteries and put them in and it should work.
Posted on Sep 13, 2008
  • snacks tasty Sep 13, 2008
    Or theres a short in the calculator I/O port. Try blowing really hard in there and that might help other than that i don't know.
My ti-84 plus got wet and now wont turn on
the only thing that I can recommend it to stick it in a zip-lock bag full of dry rice for 24hrs. Sometimes there is moisture that you just can't see & rice has a way of attracting liquids from electronic components. Hence, potentially saving your electronic device. If this does work -- if I were you I would suggest always storing your calculator, ritually, in a zip-lock bag so this does not occur again (I do this -- TI-84s are not cheap accessories -- better safe then sorry). Good luck!
Sep 01, 2014 | Texas Instruments TI-84 Plus Calculator
Are there different kinds of document cameras?
There are 3 different types of document cameras:
Ceiling visualizers - for mounting on a ceiling
Desktop document cameras - I have one of these in my classroom.
Smaller portable document cameras
Jun 19, 2013 | Office Equipment & Supplies
Screen just went blank - can bearly see a faint box in the screen
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
I work at an elementary school and the multimedia projectors are hung from the ceiling (a suspended ceiling) in a wooden tray and hanging by chains. Is this a wise choice?
First suggestion is checking to make sure that the tray/chains are secure - that it's not going to fail at at a point of connection either at the ceiling or point where the chains fasten to the tray. The tray must be strong enough for the weight of the projector (most InFocus classroom projectors are not that bulky and heavy).
Hanging anything with weight from the suspension ceiling braces is not recommended. If possible, having the wire/chain continue thru the ceiling panel (a small inconspicuous hole can be made through the panel) up to actual ceiling joists or whatever material the ceiling system itself is fastened to is best & the most secure. I've used steel aircraft cable (available at any Home Depot or hardware store) in place of chain, partly because it only requires a small pencil-sized hole thru the ceiling panel, hardly noticeable.
Most hanging fixtures (theatrical lights, projectors, etc.) have a secondary/backup safety cable or strap system should the main fasteners fail. In this case, if the tray and ceiling connection is secure, a safety strap holding the projector onto the tray so it's not sitting up there loose or able to be knocked out at all should be used. This also will help keep the projector's aim aligned to your screen should something bump the tray, you won't have to readjust it. (See this link attached for an example of a strap securing a projector).
(In all cases, if you have a building or school district maintenance administrator or someone who's job description requires them to be aware of state or district safety regulations/OHSA rules, they should be consulted to make sure you're following any safety issues that may apply specific to your classroom/student needs.)
Mar 06, 2011 | InFocus IN24 Multimedia Projector
Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
My cooler is blowing very slow can hardly feel the air
it could be any of three things.
1. its a variable speed motor and will not blow hard unless you have an extreme cooling need (5 degrees or more away from set point)
2. You have collapsed duct work.
3. Dirty evaporator coil, or filters preventing proper air flow
May 06, 2009 | Heating & Cooling
How do I mount the HC1600 projector
there are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Dec 24, 2008 | Mitsubishi HC1600 Projector
Getting more than 10 equations into y=
The TI 83, 84 seris can not store more than 10 equations. the TI 86 and above can have infinate, but not the 83, 84s. If you have catalog help in your apps, you can run that, and it will be able to tell you all the syntax of every function it has.
Nov 22, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
603 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
